Plastic Repair
Posted: 07:52 am May 02 2008
by paceyman
I busted up my front headlight shroud. Both upper supports are off and it ripped up the middle. It's $83 from the dealer and did not find an a/m replacement.
What would you suggest I use to get this back together for a few more rides before I caugh up the dough?
Thanks.
Posted: 08:10 am May 02 2008
by KarlP
The most attractive "tough guy" repair uses small zip ties. I'd take a nail, hold it with vice grips, heat the nail with a propane torch and make holes either side of the split. Stitch it together with zip ties.
I think UFO makes an aftermarket replacement that is held on with rubber straps. The rubber straps do let the shroud move on impact rather than shatter.
Posted: 09:25 am May 02 2008
by Rod Smith
There is a plastic Welder on the market and Rocky Mountain carries it. It works pretty good but you will still see the crack. $42 plus S &H but it will pay for itself if you use it a few times.
http://www.rockymountainatv.com/product ... ilyId=3540
Posted: 08:47 pm May 02 2008
by Mr. Wibbens
>|QBB<[/url]
KarlP wrote:The most attractive "tough guy" repair uses small zip ties. I'd take a nail, hold it with vice grips, heat the nail with a propane torch and make holes either side of the split. Stitch it together with zip ties.
I like bailing wire and a dremel myself
Posted: 09:41 pm May 02 2008
by 2001kdx
Zip-Ty is the way I go :)
Posted: 09:50 pm May 02 2008
by Mr. Wibbens
gotta make BIGGER holes for zip ties
Posted: 10:36 pm May 02 2008
by 2001kdx
Bigger holes?
BARELY
Posted: 10:45 pm May 02 2008
by Mr. Wibbens
unless ya got teensy lil zip tyes and those aint worth a crap for strength
bailin wire is way to go
MUCH stronger!
Posted: 05:37 am May 03 2008
by paceyman
I can see where wire or zip ties would work on the split, but not work on the mounts. Time was short since I have a race tomorrow and opted to try Plastic Epoxy. I'll snap some shots and post them after the race and report back.
Thanks for the ideas!!!!
Posted: 09:19 am May 03 2008
by skipro3
Try a piece of aluminum and pop rivet it to each half. Or, replace the broken off tab with a piece of metal you've shaped for yourself that includes a long enough overlap to pop rivet or bolt on to the main housing.
Posted: 09:38 am May 03 2008
by Green Hornet
Look for "Permanent Patch"made by "The Original Super Glue"
http://superglue.supergluecorp.com/15298.html
It's a Soft Fiberglass Patch Kit, that you cut, shape & Stick in place. It then hardens. Check Home Depot, Lowes or your Hardware Strore..
