Plastic Repair
Plastic Repair
Postby paceyman » 07:52 am May 02 2008
I busted up my front headlight shroud. Both upper supports are off and it ripped up the middle. It's $83 from the dealer and did not find an a/m replacement.
What would you suggest I use to get this back together for a few more rides before I caugh up the dough?
Thanks.
Paceyman
06 KDX200
08 KX65 - Son's
04 KTM 50SX - Daughter's
06 KTM 125SX - TBD
03 Honda CR85R - Son's
06 Polaris 300 Hawkeye - Wife's
paceyman
Has thanked: 0 time
Been thanked: 0 time
Postby KarlP » 08:10 am May 02 2008
The most attractive "tough guy" repair uses small zip ties. I'd take a nail, hold it with vice grips, heat the nail with a propane torch and make holes either side of the split. Stitch it together with zip ties.
I think UFO makes an aftermarket replacement that is held on with rubber straps. The rubber straps do let the shroud move on impact rather than shatter.
KarlP
Images: 6
Has thanked: 0 time
Postby Rod Smith » 09:25 am May 02 2008
There is a plastic Welder on the market and Rocky Mountain carries it. It works pretty good but you will still see the crack. $42 plus S &H but it will pay for itself if you use it a few times.
http://www.rockymountainatv.com/product ... ilyId=3540
2000 KDX 220
Rod Smith
Has thanked: 0 time
Postby Mr. Wibbens » 08:47 pm May 02 2008
>|QBB<[/url]
KarlP wrote:The most attractive "tough guy" repair uses small zip ties. I'd take a nail, hold it with vice grips, heat the nail with a propane torch and make holes either side of the split. Stitch it together with zip ties.
I like bailing wire and a dremel myself
Mr. Wibbens
Has thanked: 0 time
Postby 2001kdx » 09:41 pm May 02 2008
Zip-Ty is the way I go :)
2001kdx
Has thanked: 0 time
Postby Mr. Wibbens » 09:50 pm May 02 2008
gotta make BIGGER holes for zip ties
Mr. Wibbens
Has thanked: 0 time
Postby 2001kdx » 10:36 pm May 02 2008
Bigger holes? :shock:
BARELY
2001kdx
Has thanked: 0 time
Postby Mr. Wibbens » 10:45 pm May 02 2008
unless ya got teensy lil zip tyes and those aint worth a crap for strength
bailin wire is way to go :supz:
MUCH stronger!
Mr. Wibbens
Has thanked: 0 time
Postby paceyman » 05:37 am May 03 2008
I can see where wire or zip ties would work on the split, but not work on the mounts. Time was short since I have a race tomorrow and opted to try Plastic Epoxy. I'll snap some shots and post them after the race and report back.
Thanks for the ideas!!!! :supz:
Paceyman
06 KDX200
08 KX65 - Son's
06 KTM 125SX - TBD
paceyman
Has thanked: 0 time
Postby skipro3 » 09:19 am May 03 2008
Try a piece of aluminum and pop rivet it to each half. Or, replace the broken off tab with a piece of metal you've shaped for yourself that includes a long enough overlap to pop rivet or bolt on to the main housing.
skipro3
Has thanked: 0 time
Postby Green Hornet » 09:38 am May 03 2008
Look for "Permanent Patch"made by "The Original Super Glue"
http://superglue.supergluecorp.com/15298.html
It's a Soft Fiberglass Patch Kit, that you cut, shape & Stick in place. It then hardens. Check Home Depot, Lowes or your Hardware Strore..
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Green Hornet
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: No registered users and 8 guests
