Top clamp and 1 1/8 bar setup; what are you using?
Posted: 12:11 pm Apr 09 2008
by firffighter
Just curious what others are using for 1 1/8 bars. I want a new set of bars as my 7/8 Renthals are about 10 years old and bent.
Has anyone gone with a new top clamp?
Posted: 05:12 pm Apr 09 2008
by Green Hornet
I bought the "MOOSE" Flex Bars-Mini Version. By Mini, I mean the bars are approx. 30 inches Wide & Sweep Back. I bought the 1 1/8 Bar Mount Conversion Kit. It bolts in to your existing bar mounts & raises the bar height upwards approx. 7/8 - 1 inch.
Posted: 05:14 pm Apr 09 2008
by firffighter
Were those bar mounts Moose as well? How do you like your Moose flex bars? I am thinking about the new Sunline AXO bars.
Posted: 06:04 pm Apr 09 2008
by strider80
I use the Moose mini bars and "Pit Posse" big bar adapters ($35?). Search ebay for them, I think rocky mountain ATV also sells their own brand of adapter. The mini bars are a bit cramped for fitting all the controls and buttons, but they work. I am going to look at the "Burlson" bend next time around, a little bit wider.
Posted: 10:30 am Apr 10 2008
by september9
I did the front end conversion and had trouble coming up with the correct top triple clamp and a Vortex clamp with oversized bar mounts came up on eBay for cheap. So I bought it and replaced the whole upper clamp.
Posted: 02:30 pm Apr 10 2008
by Green Hornet
firffighter wrote:Were those bar mounts Moose as well? How do you like your Moose flex bars?.
Yes. They are "MOOSE" Brand
Posted: 03:26 pm Apr 10 2008
by firffighter
Cool. Thanks. I've been thinking about those Moose flex bars or the new Sunlines that are supposed to reduce vibration. I am either going to get the Moose bar mounts and put the FRP top clamp on, or put on one of the Scotts units that incluce mounts and top clamp.
Posted: 03:56 pm Apr 10 2008
by Green Hornet
Also, what I did is cut the Bar Mount Pad, that came with the Bars & Universal Bar Clamp Adapters (Two Pads), & Placed my Trail Tech in the padding. I then cut some heavy plastic & wrapped it around the Padding & Trail Tech. I'll have to take a Pic of it.
Posted: 11:13 am Apr 11 2008
by danfree
I installed the Scott's upper triple clamp and stabilizer (all in one kit). Looks great, but it is a bit overkill for my bike. Especially when/ if I decide to put the KX forks on it. Fortunately, I don't ride fast enough that the stock forks are a hinderance. I am thinking of putting some 1 1/8 bars on my dual sport (XT225). There are some bar clamps that fit into the standard 7/8 clamps. Technically they are risers, but that is kind of what I'm looking for on the Yamaha. They are relatively cheap, but I am not so sure about the engineering concept. It may put more stress (leverage) on the stock clamps. Not sure if it is safe for jumping and such, but then I don't do much of that. Except on accident!
Posted: 03:34 pm Apr 11 2008
by firffighter
So did you notice any difference with the Scotts and the stock forks?
Posted: 04:02 pm Apr 11 2008
by Indawoods
I tried it... it wasn't impressive but it did do a little... but not on big hits. On the KX frontend it works as advertised.... very confidence inspiring.
Posted: 09:01 pm Apr 11 2008
by firffighter
Well, a little is not worth the $500 bill. I am sticking with what I've got. I am going to go with the RB mods next.
