Athena Piston Kit
Athena Piston Kit
Anybody ever use an Athena piston kit for thier KDX? Just got one in for my 2000 KDX 220. I asked for a Wiseco when I ordered it from my local shop but got an Athena delivered instead. Just wondering about the reputation for quality....and if I should exchange it for a Wiseco. I've read a lot about guys having good results with Wiseco pistons.
First... If I ordered a Wiseco, I'd expect a Wiseco.
I believe Athena makes the Bore Kits for the Thumpers....
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Thanks, that will put my mind at ease. I was hoping the reputation of German quality would apply to this situation.
Yeah, I know. I really did expect a Wiseco. The shop owner is a friend, always gives great service and advice so I didn't gripe when he said all of his sources were back ordered on the Wiseco pistons.....Which is why I bought from him instead of ordering online. I like to support small business, and I can give him a call if I run into a problem and need some advice.
- skipro3
Clearances? I know checking them is the right way to do things but I'm affraid this back yard mechanic doesn't have any micrometers. I've heard the cylinders on these bikes are tough as nails and wear very well. I was hoping to put it all together and hope for the best. Bad idea? I've got a new piston, pin, bearing, rings, circlips and cometic gasket set.
At the risk of a flame...I would primarily check the ring end-gap. Feeler guages are cheeeeep...but that is where you *could* experience a problem.
Piston (without rings) should move freely in the bore when placed/aligned properly(arrow!)....and you did say the cylinder coating is in great shape, right??
Make sure you warm the engine *properly*....meaning the cylinder is warm/hot to the touch *before* applying a boot-full of heat/pressure to the whole works. Risk is that the piston expands more than the cylinder and seizes in the bore.
Not many manufacturers ship pistons that are too big for a standard (and used) bore!
Use extreme care when installing the circlips! ie: Rag in the cases....careful fitment. if you damage the circlip or over-tweak it...GET A NEW ONE!!...they're cheap, too, relative to the damage they can cause.
Let us know!
Let us know!
- Jeb
At least make sure the box/package indicates correct piston size. And it wouldn't hurt to make sure it's about 69mm in diameter with whatever you can measure with just to make sure you don't have the wrong piston.
Check ring gap - place the rings one at a time in the cylinder about 10mm or so down and check with feeler guage(s). Wiseco recommends a minimum of 0.004" per inch of piston diameter which equates to about 0.011" for your 69.0mm piston, I don't see why the same wouldn't true for other makes. I've gotten from 0.012 to 0.016 or so when I try so it's a good thing to check.
As you reassemble, before you bolt on the lid cycle it through a stroke or two just to see. hear, and feel that things seem fine.
- Jeb
That coating doesn't wear much. Look for grooves and or flaking. SO, an excess end gap wouldn't be a cause for concern to me (within reason) but, TOO SMALL an end gap means you're soon to experience a broken ring.
I bet it's within spec, but you do need to ck, cause the damage is BIG-TIME BAD!
Just one add to Jeb's comments.....use the piston crown(top) to level the ring in the cylinder. And remove and place it with great care, so as not to damage.
- Jeb
- RBD
Yikes. That would be a pretty big difference in height.
Lacking a suitable measuring device...perhaps setting them up beside each other will point out any obvious difference and .020 is quite visible with a background reference point for your eye.
Bit crude, I know, but sometimes you can still get a clear idea, using a little ingenuity. If there is that great of a difference, then you better not just throw it together.
I think Ron really knows what he's talking about here.
- skipro3
You should do these checks no matter what piston you stick in there. It's just a surety that you have the right parts and that they fit YOUR cylinder.
Don't worry, it's not complicated or anything. After the first time measuring, you will be the expert.
