UFO Ray Headlight
Posted: 06:23 pm Mar 04 2008
by marpit
Does anyone have this headlight? was just wondering if the stock stater will run this and how bright is it? thanks for any feed back
http://www.denniskirk.com/jsp/common/im ... 79&imgId=0
Posted: 03:30 pm Mar 05 2008
by september9
Ray kit features a 12V/35W light
Ray Halogen kit has a super-bright 12V, 60/55W light
Do you want the normal Ray or the Halogen? From reading this forum, the KDX can only handle up to like 40 watts stock. So if you stick with the normal Ray you should be fine.
Posted: 05:53 pm Mar 05 2008
by marpit
I was looking at the Ray reg kit which uses a 12V/35W light so i should be fine....thanks for the info
Posted: 08:14 pm Mar 05 2008
by AwfulSmokey
marpit wrote:I was looking at the Ray reg kit which uses a 12V/35W light so i should be fine....thanks for the info
Yes, you will be fine. I have an Acerbis DHH (twins) on mine. It has 35 watt/55 watt bulbs. I hooked up to the 35 watt and it's nice and bright. It won't power the 55watt.
Posted: 09:06 pm Mar 05 2008
by marpit
BTW...any suggestions on a LED taillight???
Posted: 09:11 pm Mar 05 2008
by jeopardy98
I just noticed that the halogen version of that light claims a 55w bulb but the UFO halogen bulb replacement claims 35w. It appears to be the same bulb that is used in the twins headlight which we know to be 35w.
Do you all think that this single halogen Ray headlight is actually 35w? I need to do some more research.
Posted: 10:03 pm Mar 05 2008
by TWMOODY
You can buy LED rear bulbs at Auto Zone for about 5 bucks.
I think it is a 1156 0r 1157 LED
Posted: 08:18 pm Mar 07 2008
by canyncarvr
I've purchased a couple of the 1156L units from Schucks. They couldn't handle the vibration...ended up in teeny liddle peaces after a couple of rides.
Others have had better luck.
Consider an RV marker light...the type you would have to surface mount to either the fender or the lense. They're potted...won't be coming apart.
I've got one'a those. Have had for a good long time...just haven't put it on, yet!
Posted: 08:53 pm Mar 07 2008
by Mr. Wibbens
Whatever!
Posted: 10:29 pm Mar 07 2008
by DaBen
I have the ray halogen on my DRZ and once I put a silverstar bulb in it, it was great. I liked how adjustable it was so I was able to get it to shine right where I wanted it.
Posted: 10:55 pm Mar 07 2008
by Mr. Wibbens
I found this at Wallyworld
Held up to my abuse for 4 years so far
http://www.pmlights.com/products.cfm?cId=1&fId=54
