Donut gasket for pipe?
AwfulSmokey
Post by AwfulSmokey »
Is there supposed to be a donut gasket that goes around the pipe where it goes onto the motor?
I used some foam and de-greased my bike. Now that it's so clean i noticed oil coming from the front of the motor. It seems like the pipe doesn't fit so well. There's a small space on top. It kinda looks like the pipe may be tweaked a little. I seen that fredette sells a gasket that's supposed to build torque. Would this cure my problem?
No donut... there is a big flat copper ring that goes between the pipe and the cylinder. An easy cure is to use Silicone around the neck of the pipe and install it. Let it set up over night and she should be good to go....
Rick
Post by Rick »
RTV High Temp Silicone lasted all season for me! Clean well before applying.
1996 Suzuki DR 350 $Sold!
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
KDX Butterfly
Queen B
Queen B
Post by KDX Butterfly »
Rick wrote:Clean well before applying.
With what do you suggest?
"If I were just two inches taller, I wouldn't be me." ~KDX Butterfly
Mr. Wibbens
Post by Mr. Wibbens »
Carb cleaner works good
Rick
Post by Rick »
Yep! I think i used brake cleaner. Be careful. That stuff is potent on paint and plastic & rubber.
2002 DL1000 V-STROM
GS
Post by GS »
Another vote for brake cleaner or acetone
Re: 'I seen that fredette sells a gasket that's supposed to build torque.'
That a reference to his torque ring? But..that's not a gasket.
If your pipe/cylinder connection leaks due to a tweaked pipe (most pipes are..all it takes is one bad get-off), a torque ring isn't going to fix it.
The gasket mentioned keeps the pipe from banging against the cylinder..I'd want to use one regardless of how well the pipe sealed just to give the two pieces some cushion.
I use two of 'em...so that makes my pipe fit twice as good. :wink:
