1999 KDX 200 Engin oil capacity
ccassid1
Post by ccassid1 »
Quick question, engine oil capacity?
Thanks. :supz:
billys04kdx200
Post by billys04kdx200 »
On my 04 it is stamped on the side of the engine case. To cold to go out and check but i think it is 650 ml.
urnuts
Tenn?
Post by urnuts »
And it's too cold?
You sissy!
Ondatrail
Post by Ondatrail »
700 ml. Get a Ratio Rite they're GGGRRRRREAT!!!
I am the Night Rider! I’m a fuel injected suicide machine! I am a rocker, I am a roller, I am the out-of-controller
Put the quart in and call it good!
What was the point of the question? Wondering specifically for some reason, or looking to find how much to put back in on an oil change?
If it's oil change..don't put in the spec amount....too much engine noise when you use what's spec'd.
..ergo..what Inda said. Maybe use 150ml or so of the quart as a 'flush' (rinse out summ'a those leftover transmission bits and pieces) before you put the drain plug back in.
