Hi Guys. Been lurking here for a bit. Lots of good info here. I just got my 220 cylinder replated. I did not pay attention to the the oil seals(on the KIPS shaft that runs parallel to the crankshaft), when I took them out. Which way does the open side go, on these seals? Thanks in advance.
Eric
KIPS seals?
'Tis true...'tis always true. Not just this seal..any similar seal.open side is oil side or closed facing out
PN 92049-1238 looks like this:
You're looking at the 'open' side.
This same seal is used in a number of places on the KDX.
Re: How to post a pic
Put the URL link to the pic between BBCode img tags. BBCode tags are placed between brackets, [ and ]. Considering that a lot of websites do not allow linking (reference to a pic on their website from another site for example), upload the desired pic into your KDXRider gallery, copy the string (right click on the opened picture, select properties) into the *img* code string.
simple pimple
You ARE putting a Wiseco in that cylinder, right? At any rate, NOT a Pro-X?
>|QBB string (right click on the opened picture, select properties) into the *img* code string.
simple pimple
You ARE putting a Wiseco in that cylinder, right? At any rate, NOT a Pro-X?[/quote]
Thanks for the photo loading tips, Canyon Carver, and yes a Wiseco piston was sent, to the platers, along with the cylinder.
Thanks again, guys.
simple pimple
Thanks again, guys.
