Indawoods wrote:Yes... you should always thoroughly warm up your bike when running a Wiseco piston!
Hmmmm, I usually let mine idle a little bit, maybe a minute or two, then take it for a spin. Usually takes 75 - 100 yards to clean out and get on the pipe, then she's ready
Warning! This member tends to use sarcasm as a regular form of communication. If a post seems offensive, before you panic and fly off the handle, re-read the post and imagine it being said with a sideways grin. ((Bike Profile)) ((Pics))
Not really what i asked mate....
I asked if it takes longer for a wiseco piston to warm up, vs the stock piston.
The stock one seemed to be warmed up within a 1 minute maybe 2, the wiseco seems to take about 4 or 5. Is that normal?
Yes was the answer... which is the correct answer.... MATE.
A Wiseco is forged... your stock piston was cast. The cast is very close to tolerance no matter what temp it is. A Forged on the otherhand takes longer to warm up and come to tolerance.... it is a higher grade piston than the cast piston. It may not be what you asked... but you need to understand what you did to your bike.
Oh...Good advice there Wibby! Remind me to never take your advice....
*** Administrator //*** ****'95 KDX 200/****
Been running the same wiseco piston fer at least 3 years
Somebody leave the backdoor open an Okie and Rich snuck in?
that is the exact kind of answer i was looking for, thank you!
ran the bike today up to about 4500 feet above sea level, the bike was transformed! a 142 jet and the clip 2nd from the top did it. Bike was wonderful. I also put in an eg plug.
I think i need a bit more HP so RB mods to come...
[quote="cleoent] Isn't that what they normally came with? I'm wondering if there is one out there with a bit more performance... the EG? What about iridium?[/quote]
Nope IMO those are just a gimmic and nothing else.
Screwed up on the quote thing but oh well
I am the Night Rider! I’m a fuel injected suicide machine! I am a rocker, I am a roller, I am the out-of-controller
