Headlight?
staxbrix
Headlight?
Post by staxbrix »
Anyone have a wiring diagram for a 88 kdx 200?
Im trying to install a headlight since it gets dark around 4.
I have a 12v 55 watt atv light will the magneto power this? Or should I get a weaker bulb.
I have a diagram from a later model wich has a 35 watt front and 10 watt brake light.
AwfulSmokey
Post by AwfulSmokey »
I have one from 89-94.
Image[/img]
AwfulSmokey
You brought up a good point stax. I just won an Acerbis DHH on ebay for $40 in mint condition. It has dual 35W bulbs. Will the bike be able to run it?
staxbrix
Post by staxbrix »
Does anyone know what the electric system puts out?
We dont need fried electrics here.
I think ill be alright maybe a tad dim. You could unplug a light and be on spec. Alot off stuff is overrated so that might come into play.
Uh.. no. You will not be able to run it. Good enough or do you need an explaination? Your stator does not put out enough juice.... betta? :grin:
skipro3
Post by skipro3 »
You can run one of the 35w bulbs but not both at the same time.
staxbrix
Post by staxbrix »
Yeah I would like a better explantion.
The diagram shows it has enough power for 40 watts. So I dont think 55 would push it. As I said the bulb might do 55 in perfect conditions. I can see how 70 would put a strain on the electrics if its meant for 40-50.
Actually...35 is pushing it. The stock setup is strained out of the box. Others have tried believe me... they either went back to the stock light or upgraded the lighting coil to a aftermarket one.
staxbrix
Post by staxbrix »
Im going to try to find a 30 watt then. Maybe a Xenon that might brighten it up a bit.
A idea for the night riders, A HID headlight coversion. There mostly for luxury cars but might be worth it for anyone thats rides alot at night. Probaly more suited for street bikes.
AwfulSmokey
After reading this, i went and did some searching. I seen alot of posts saying go to rickystator.com $40 for a rewind. I contacted Ricky Stator and asked how much. The reply i got was $100 for 75w.. Big jump in price or is my stator different?
KarlP
Post by KarlP »
I tried a UFO lamp and plastic shroud when I smashed mine. Two 30 watt filaments, I think? No way, it barely turned orange.
I put the old bulb in the new housing and it is back like stock. 35 watts is not going to make enough light to ride at night, in my opinion, I don't care how it is delivered.
Stock combined with a good helmet light might work.
I've taped a flashlight to my helmet before, searching for lost riders :lol:
skipro3
Post by skipro3 »
The light isn't meant for riding at night, it's meant to get out of the woods without killing yourself. If you are looking to recreate at night, you're going to need a lot LOT more than the bike can ever deliver.
I swapped to an LED bulb I found off the internet. I could not muster any more candle power than the 30W filament bulb would deliver but at least I won't burn out a filament.
Mr. Wibbens
Post by Mr. Wibbens »
skipro3 wrote:The light isn't meant for riding at night, it's meant to get out of the woods without killing yourself. If you are looking to recreate at night, you're going to need a lot LOT more than the bike can ever deliver.
Maybe the stock set up
Add a higher output coil and the UFO twins light and you can ride at night all you want
staxbrix
Post by staxbrix »
The path im going down is lighted on both ends and runs along a lighted bridge. Under the bridge theres big hills where the supports are dug in. I managed to ride with a 9 led flashlight zip tied to my handlebars..
I just went to 3 stores looking for a smaller bulb and I cant find one for my light housing.
I found a complete 35 watt light with no mounting for $10 at advanced auto parts.
staxbrix
Post by staxbrix »
the wire coming off the magneto is yellow/black and red on my bike. And yellow and red in the diagram. should I plug into y/b or red.
And with the kill switch should I take the end thats grounded and plug that into the light and ground it in the middle? or splice it?
What's the source of the above diagram?
It looks a tad strange. No voltage regulation? From the coil, though lights to ground?
I doubt it.
Re:
This is similar to earlier questions/posts if I recall correctly.
You're saying THE wire (meaning one)..is a lot of colors. Obviously, that isn't so. Maybe you mean the wireS..but then, why the 'is'.
Here's a good way to mess up stuff. Wire up something according to any answer you get to such a question.
Note that in the diagram there is ONE wire that runs the lights..it's yellow. The lighting coil (on the 'H' model..and I doubt any different on the 'E' model) has only on wire out of the stator, the other end of the circuit (the other end of the coil) being tied directly to the engine case (ground).
Sorry again..but I make no sense out of that at all. The kill switch has nothing to do with the lights. It's not connected to the same power circuit. There is only one ground reference..and that is frame ground. Maybe they're all connected at the same physical point, maybe not.
Answers are good...but only if they're good answers..and those aren't to be had with questions that cannot be understood.
Please do rephrase...and succinctly at that?
A good place to start is to know what's under your rotor/flywheel. If you are ADDING lights (as opposed to replacing lights that have been working), start by determining you HAVE a lighting coil in the first place.
Wire an unregulated lighting coil (as the diagram indicates) into the CDI..and things won't go well.
m0rie
Post by m0rie »
Actually the diagram he references is correct for a 89 (and possibly 90) KDX 200. They did not have a voltage regulator in the circuit.
I think I'd been told that before.
Just checking!
Thanks, M0rie!
Do you know if it applies to an '88?
staxbrix
Post by staxbrix »
Look at where the bl wires from the light connect to the kill.
I was asking does it need to be connected to that wire or just ground ?
If it just needs to be ground, Then I can ground it on a bolt that mounts the light. Instead of splicing into the wire to connect them.
In the pic it grounds them at a point in the middle.
Ill put up some pics in the afternoon.
Mr. Wibbens
m0rie wrote:Actually the diagram he references is correct for a 89 (and possibly 90) KDX 200. They did not have a voltage regulator in the circuit.
Just curious, whats the vr for then?
Kawi fiche shows the 89 as having a vr :?
