Replacing Sprocket Question
I ordered a 12 tooth front sprocket to replace the 13 that is on there, will i need to get a shorter chain or remove a link? I took my carb apart yesterday and ordered jets, so while it's immobile i want to go ahead and do some other things.
There are caveats.
If your chain is close to being maxed out adjustment-wise with a 13, you won't get within a reasonable adjustment range with a 12.
Guess that is pretty self-evident. A 108 is used for both 13/47 and 12/47. As long as the chain is in good shape, it'll do fine.
Another 'everybody has one'....
I've had far better luck with Renthal sprockets of the CSS type than any other. Others (SunStar, J..uh..what is it..K?..the two initial sprocket name) don't fit on the shaft for diddle..way too loose, and they get LOOSER with wear. Renthal doesn't have that problem.
- Jeb
- skipro3
- Mr. Wibbens
Dunno what I run but it aint rethnals!
Never had no problems
- radonc73
- 2001kdx
50 Z-sprocket on the rear and 13 Rethnal on the front.
