Spring swap, do u have to remove fork?
- cleoent
All the guides i've seen show the forks being removed from the bike, do you have to do that???
And if it's not too much trouble, can someone tell me why you have to remove them?
- TopperHarley
you dont
put the bike on a stand. you will need to remove your bars.
remove the cap which is threded into the top of the tube with a 30mm socket
2005 KDX220 mine
2005 KDX220 mine
uh... no.
Just support the bike by the frame.... make sure the front forks are off the ground. Loosen the top pinch bolts... uncrew the caps to get to your springs... careful... they are under pressure by the spacers...
- cleoent
ok so this guy definitely did too much work.
http://www.dishers.com/hobbies/Repairs/
I'll give it a go and report back with any probs. Thank you so much!
I feel like i should pay to use this site!
Don't let me hold ya back!
- TopperHarley
you will need to collaps the spring a bit by pulling down the spacer and slip a wrench on the nut that is underneath the cap. put the 30 mm socket back on the cap and remove it from the rod. Voila! remove spacer, washers and spring.
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
donations to the site are gladly accepted.
2005 KDX220 mine
2005 KDX220 mine
It's actually nice that the forks are still on the bike... it holds the tubes for ya....
- TopperHarley
if you were going to change your oil, put in new seals, etc. you would need to take them off the bike.
will you be using the stock preload spacers?
2005 KDX220 mine
2005 KDX220 mine
- cleoent
- TopperHarley
its difficult..try pulling it down and slippin a smaller maybe flat wrench if you have one, with the mouth that will fit around the rod but smaller than the backer nut. this is how I hold it down.
if you have both caps off, you may want to place somethin under the front tire to raise the springs out of the tubes a bit. give you some room to work
the stock spacers are large. about 30 mm of preload i think. target preload is 10-12mm
2005 KDX220 mine
2005 KDX220 mine
Target for me is about 5mm....
- cleoent
You have to measure the 2 different spring lengths and determine what the preload length of the spacer will be. 1" Schedule 40 PVC works best for spacers instead of the stock metal tube.
- TopperHarley
if you drop the new spring into place, thread the cap on all the way. measure the distance between the bottom of the cap and the top of the spring. you want you spacer and your washers to fill this gap + the amount of preload you choose to try.
2005 KDX220 mine
2005 KDX220 mine
- cleoent
ok here's a pic. I dont know if perhaps i'm doing something wrong, but it seems like they are already a big preloaded. the spring is pushing the two washers together, does this sound normal?
If that's normal, then what my plan is to measure between the two washers and add 10mm, sound good?
- TopperHarley
how much space w/out the washers?
measure w/out washers in place......take this measurement and add your preload to it .....subtract thickness of washers(only the flat surface not the sleeve part this will fit inside the spacer).....this is what you will cut your spacers to.
does that make sense or just confuse you?
NEXT PAGE
NEXT PAGE
2005 KDX220 mine
2005 KDX220 mine
