Replaced some parts...
m0rie
Post by m0rie »
Replaced my shift shaft which had stripped out completely. Pretty easy job if you take your time. Between it and the new shifter there is zero slop now in my shifting. Feels nice and tight and very responsive. Much nicer than it used to be. Also switched out my tweaked 7/8th inch Renthals for a set of Fat bars and at least from my lite riding around the yard i'm sold on Fat Bars. Seems like a great deal of the vibration that I used to feel in the bars is gone now. All in all a couple of much needed improvements.
1989 KDX 200
2007 TTR-50E
strider80
Post by strider80 »
Do you have to pull the clutch to pull the shifter shaft? Mine is about clapped out.
2005 KTM 250EXC
2000 KDX200 (gone)
m0rie
Post by m0rie »
Yep, everything on the clutch side needs to come off.
1989 KDX 200
2007 TTR-50E
strider80
Post by strider80 »
Engine cover too? Not just the clutch cover?
2005 KTM 250EXC
2000 KDX200 (gone)
m0rie
Post by m0rie »
Yeah, _everything_...Drain the coolant, pull the water pump, clutch and engine covers. PITA but not too hard over all.
1989 KDX 200
2007 TTR-50E
Jeb
Post by Jeb »
M0rie - If you don't mind me asking what did ya' end up spending, total, when you went to the 1&1/8 bars? I was considering fabbing/installing a singe-tank subtank - a custom kind-of-thing, others have done it, where oil can drain back down into the forks. There's really not enough room with the 7/8 bars to do this so I was a 'wondering . . .
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
IdahoCharley
Post by IdahoCharley »
Jeb wrote:M0rie - If you don't mind me asking what did ya' end up spending, total, when you went to the 1&1/8 bars? I was considering fabbing/installing a singe-tank subtank - a custom kind-of-thing, others have done it, where oil can drain back down into the forks. There's really not enough room with the 7/8 bars to do this so I was a 'wondering . . .
Not MOrie here but - There are simple bar risers available from Rocky Mountain for about 20 bucks that will raise your bars and give you enough access room so you can install a fittings on top of the fork legs. Sub-tanks seem like a good idea which I'm also thinking about.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
m0rie
Post by m0rie »
When I bought my clamps for the KX conversion I got 1 1/8th mounts in the deal. Ski gave me some adapters for my bark busters and the bars were Longhorn cheapies from Rocky Mountain MC ($30 on closeout).
1989 KDX 200
2007 TTR-50E
Jeb
Post by Jeb »
Rocky Mountain bar risers: SMACK! (that's the palm of my hand hitting my forehead) I was pondering on those anyway for more bar height to suit aggressive riding stance a little better but they'll double as making more room.
RE: Closeout cheapies - that's the way to go, I'm always on the lookout for something myself!!
CLICK FOR PICS!
