MXOldtimer wrote:Don't listen to these guys, loud is where it's at man.
Don't settle for just removing the S/A. I'll help you get the ultimate MX sounding KDX.
Things you'll need, hacksaw, roll duct tape, and a inch and a half hole saw, 4 feet of vacuum hose.
It's best to steal your Mom's or neighbors vacuum hose to keep the cost down.
Getting started, take the hacksaw and cut the header pipe just after it makes the turn from the engine. Remove the rest of the expansion chamber w/ S/A and discard. (your even saving weight)
Now slip the vacuum hose over the end of the pipe and use the duct tape to attach it securely. Now take the inch and a half hole saw and put a hole in your helmet right where your right ear should be. See where I'm go'n with this?
Now take the vacuum hose you connected to the pipe and push the other end into the hole you just made in your helmet. Make sure you have enough length so you can stand and move around on the bike. Duct tape securely to the helmet.
Strap that helmet on, kick that bike to life and man will you have the sound your look'n for!
You can take it one step further and steal more vacuum hose put a "Y" in the hose and cut a hole on the left side of your helmet and have STEREO MAN!
Now if you don't wear a helmet cuz I'm sure no one cares if you wear helmets in the Dominican Republic you can just tape the vacuum hose directly to your ears securing it with the duct tape.
That's just harsh, but darn funny. Gionix is probably a young kid that doesn't know any better and want to be kooool as alll of his other buudies with loud pipes. Hopefully he'll get the idea from you guys that lookin' kool doesn't make you any faster
