I've got a crack in a tank for a '99 CR250.
The crack runs right under the petcock area and is ~1.5" long
It looks like it was caused by the PO having trouble with the petcock and trying to remove the petcock. When the nutsert spun in the tank, it cracked the tank.
I got both nutserts out by putting an 8 mm socket on my drill and spinning the nutserts and prying on the petcock untill they came out.
I plan to use a spare KDX petcock I have. I know it was a good one.
I'm not going to worry about future removal of this petcock and plan to glue it in place.
I do have a plastic welder and have done a fair bit of plastic welding in the past. I'm sure I can close up the crack, but I'll never get it back to stock configuration where nutserts are used to allow bolting of the petcock to the tank and an o-ring provides the seal.
I've got a glue sample on the tank right now, soaking in gas. It is an epoxy used for repair of fiberglass tubs and showers, etc.
Does anybody out there have experience with succesfully gluing these plastic tanks?
Best glue for gas tank?
- skipro3
My experiance is that the bike's vibration will eventually cause any glue to fail. I'd get it welded by someone who professionally welds plastics. I had mine done by a ski technician who repairs the bases on skis. He pumped a little nitrogen tube into the tank to displace any air so as to reduce any explosive hazard from fumes.
Ahh well...
I welded up the crack, no problem.
Epoxied the nut serts back in the holes they came out of let that set up.
Bolted the KDX petcock to the CR tank with more expoxy between the tank and petcock. Nice clean job, looked good.
As expected, it started to leak after 96 hours. Just weeping out all around the petcock.
I got to ride the CR/KDX Saturday and Sunday and Monday after work. Just short rips around the back 40. Lots of chassis and controls tuning to do.
New tank is $ 213.00 from Monkeybutt
- Ondatrail
I just used this on the filler stem on my tank: http://www.eclecticproducts.com/sealall.htm
idk if it will help in your situation but it was under $5 at the local hardware store so i think it could be worth a shot
I am the Night Rider! I’m a fuel injected suicide machine! I am a rocker, I am a roller, I am the out-of-controller
- skipro3
Check out this inside the tank sealer stuff. It worked good on my old metal Honda tank. Sealed the leaks and stops rust too!
http://www.kbs-coatings.com/KBS-Gas-Tan ... r-C38.aspx
Waz
Waz
"Roads? Where we're going we don't need roads!" - Emmet Brown
- Colorado Mike
