Cleaning Stinger
Johnny
Cleaning Stinger
Post by Johnny »
I just pulled the silencer packing on my KX250 and it was very ugly. The packing was black and alot of the holes in the stinger were pluged with that black tar 2-stroke of unburnt fuel oil mixture goodness. Any suggestions on how to clean out the stinger would be much appreciated. I recently changd the packing in my KDX220 but the stinger was not as bad as my KX.
Thanks.
have you tried a wire brush? That's what I do on mine, works good. If the "goodness" is too hard and still plugs the holes, I use a screwdriver to unplug every hole (tidious but work., now I learned my lesson and do it more often :wink: )
Johnny
Post by Johnny »
I guess that would be the obvious choice but of course I didn't think about that. When you clean it with a wire brush can you get it into the inside also? Is there anyway to burn it off?
Ondatrail
Post by Ondatrail »
I used brake parts cleaner and the stuff came right off with out brushing. Said to do so on the new packing bag.
I am the Night Rider! I’m a fuel injected suicide machine! I am a rocker, I am a roller, I am the out-of-controller
Johnny
Post by Johnny »
Brake parts cleaner is some good stuff. I tried it and while it did a great job on the outside, the inside was still kind of nasty.
smaller brush on the inside
Ondatrail
Post by Ondatrail »
I'd use one of these:
>|QBB<[/url]
Ondatrail wrote:I'd use one of these:
no offense, but good luck with that!
thebleakness
Post by thebleakness »
Best stuff I've found for getting rid of that exhaust grease/spooge is "Gunk Engine Degreaser". Spray it on, let it sit for a few minutes and then wipe it off. Speaking of which, I really need to buy more of it....
Not all Gunk is good gunk...imo
The foaming Gunk junk is...well...junk.
The "heavy duty' stuff cuts a lot more goo a lot more quicker.
...never used it on the S/A core. A wire brush has always been sufficient in making me feel I was accomplishing something, but... I have yet to have a hole plug up.
YCCC (Yamaha Combustion Chamber Cleaner) is rumored to be the fang-dangledest carbon cleaner in the entire space of the 3rd rock from the sun.
..haven't tried that, either..
What a wealth of information!!
Please....hold the applause....
..no...really!
2001kdx
Post by 2001kdx »
Wire brush should be all you need... No applause for you CC.
Let me know how that wire brush works out on the spark arrestor...maybe take some pics.
Rick
Post by Rick »
If you set up a good clamp/holder for the stinger, engine de-greaser, soaked for a few, and a pressure washer works great......And, no dried out hands!
1996 Suzuki DR 350 $Sold!
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
wanaride
Post by wanaride »
I use YCCC, got the tip from Wibby about a year ago...that stuff is awesome! The spooge just runs away! I've never even needed a wire brush with it.
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
fLyNbYu
Post by fLyNbYu »
I just cleaned the core last night with a torch. It actually was glowing red after the flames went out. Dunno if it hurt anything, but it burnt everything up and all i did was tap it on the ground and some residue flaked off and it was all clean.
'01 KDX 220R
'01 XR650R SuperTerd
fLyNbYu wrote:I just cleaned the core last night with a torch. It actually was glowing red after the flames went out. Dunno if it hurt anything, but it burnt everything up and all i did was tap it on the ground and some residue flaked off and it was all clean.
the torche works great doesn't it? You did not hurt anything, it's just a tube with holes in it :wink:
fLyNbYu
Post by fLyNbYu »
scheckaet wrote:>|<>QBB<
The torch was awesome :supz: I will do it again on the next re-pack.
'01 KDX 220R
Johnny
Post by Johnny »
I betcha that smelled good. I tried using my the electric burner on my stove by holding the stinger up against it and rolling it back and forth. The place got pretty smokey pretty fast. I had to hurry up and air the place out before my wife got home and threw a fit. I liked the smell, but what smells good to me does not usually smell good to my wife. For example I like the smell of my own farts (doesn't everybody?) but she thinks they stink, well I guess I think they stink too but a good stink. Okay, I'll stop now.
KDXSean
Post by KDXSean »
Think I heard someone once say they took the s. a. apart, threw it in the campfire while they drank a dozen beers or so.
Multi tasking I believe they call that.
Believe it came out clean though.
Mr. Wibbens
Post by Mr. Wibbens »
YCCC works awesome
It'll even take carbon off the top of you piston with a toothbrush
Regular carb cleaner works pretty good too
