Cleaning Stinger
Posted: 06:52 pm Aug 28 2007
by Johnny
I just pulled the silencer packing on my KX250 and it was very ugly. The packing was black and alot of the holes in the stinger were pluged with that black tar 2-stroke of unburnt fuel oil mixture goodness. Any suggestions on how to clean out the stinger would be much appreciated. I recently changd the packing in my KDX220 but the stinger was not as bad as my KX.
Thanks.
Posted: 06:57 pm Aug 28 2007
by scheckaet
have you tried a wire brush? That's what I do on mine, works good. If the "goodness" is too hard and still plugs the holes, I use a screwdriver to unplug every hole (tidious but work., now I learned my lesson and do it more often
Posted: 07:08 pm Aug 28 2007
by Johnny
I guess that would be the obvious choice but of course I didn't think about that. When you clean it with a wire brush can you get it into the inside also? Is there anyway to burn it off?
Posted: 07:28 pm Aug 28 2007
by Ondatrail
I used brake parts cleaner and the stuff came right off with out brushing. Said to do so on the new packing bag.
Posted: 07:36 pm Aug 28 2007
by Johnny
Brake parts cleaner is some good stuff. I tried it and while it did a great job on the outside, the inside was still kind of nasty.
Posted: 07:37 pm Aug 28 2007
by scheckaet
smaller brush on the inside
Posted: 08:04 pm Aug 28 2007
by Ondatrail
I'd use one of these:
Posted: 08:56 pm Aug 28 2007
by scheckaet
>|QBB<[/url]
Ondatrail wrote:I'd use one of these:
no offense, but good luck with that!
Posted: 09:21 pm Aug 28 2007
by thebleakness
Best stuff I've found for getting rid of that exhaust grease/spooge is "Gunk Engine Degreaser". Spray it on, let it sit for a few minutes and then wipe it off. Speaking of which, I really need to buy more of it....
Posted: 08:27 pm Aug 29 2007
by canyncarvr
Not all Gunk is good gunk...imo
The foaming Gunk junk is...well...junk.
The "heavy duty' stuff cuts a lot more goo a lot more quicker.
...never used it on the S/A core. A wire brush has always been sufficient in making me feel I was accomplishing something, but... I have yet to have a hole plug up.
YCCC (Yamaha Combustion Chamber Cleaner) is rumored to be the fang-dangledest carbon cleaner in the entire space of the 3rd rock from the sun.
..haven't tried that, either..
What a wealth of information!!
Please....hold the applause....
..no...really!
Posted: 08:36 pm Aug 29 2007
by 2001kdx
Wire brush should be all you need... No applause for you CC.
Posted: 08:47 pm Aug 29 2007
by canyncarvr
Let me know how that wire brush works out on the spark arrestor...maybe take some pics.
Posted: 09:37 pm Aug 29 2007
by Rick
If you set up a good clamp/holder for the stinger, engine de-greaser, soaked for a few, and a pressure washer works great......And, no dried out hands!
Posted: 09:49 am Aug 30 2007
by wanaride
I use YCCC, got the tip from Wibby about a year ago...that stuff is awesome! The spooge just runs away! I've never even needed a wire brush with it.
Posted: 11:12 am Sep 06 2007
by fLyNbYu
I just cleaned the core last night with a torch. It actually was glowing red after the flames went out. Dunno if it hurt anything, but it burnt everything up and all i did was tap it on the ground and some residue flaked off and it was all clean.
Posted: 01:15 pm Sep 06 2007
by scheckaet
fLyNbYu wrote:I just cleaned the core last night with a torch. It actually was glowing red after the flames went out. Dunno if it hurt anything, but it burnt everything up and all i did was tap it on the ground and some residue flaked off and it was all clean.
the torche works great doesn't it? You did not hurt anything, it's just a tube with holes in it
Posted: 12:34 am Sep 08 2007
by fLyNbYu
scheckaet wrote:fLyNbYu wrote:I just cleaned the core last night with a torch. It actually was glowing red after the flames went out. Dunno if it hurt anything, but it burnt everything up and all i did was tap it on the ground and some residue flaked off and it was all clean.
The torch was awesome
I will do it again on the next re-pack.
Posted: 10:27 pm Sep 09 2007
by Johnny
I betcha that smelled good. I tried using my the electric burner on my stove by holding the stinger up against it and rolling it back and forth. The place got pretty smokey pretty fast. I had to hurry up and air the place out before my wife got home and threw a fit. I liked the smell, but what smells good to me does not usually smell good to my wife. For example I like the smell of my own farts (doesn't everybody?) but she thinks they stink, well I guess I think they stink too but a good stink. Okay, I'll stop now.
Posted: 06:00 pm Sep 10 2007
by KDXSean
Think I heard someone once say they took the s. a. apart, threw it in the campfire while they drank a dozen beers or so.
Multi tasking I believe they call that.
Believe it came out clean though.
Posted: 12:20 am Sep 11 2007
by Mr. Wibbens
YCCC works awesome
It'll even take carbon off the top of you piston with a toothbrush
Regular carb cleaner works pretty good too
