trans oil quantity
trans oil quantity
how many ounces of trans oil does an 03 kdx220 hold?is the site window correct?mine seems full at 18 ounces.
Put the entire quart in there and call it good... helps quiet down the clutch.... doesn't hurt a thing on a KDX.
What 'seems full' and what you see in the sight glass are related...neither of them tell you much.
Use a couple ounces of your quart to flush out the case after draining. Use the balance IN the case.
'H' model spec is 700ml.
A quart is 946ml.
A quart is 946ml.
