Full Syn and Semi Syn oil together? or mortal enemies?
cfspawn
Post by cfspawn »
Hey all.
had some weird issues with my bike in the last couple rides.
On my 2nd last ride i forgot my 2T oil (as you do!) so had to borrow some of a mates motul fully synthetic. bike performed well on this but next ride i reverted back to my motorex semi synthetic and still had prob 5-6 ltrs left in the tank ofr premix full synthetic
since then my bike is a bitch when either starting or in the low range revs it just dies as if i have bad fuel or poor spark, mid range and top end is fine.
could this be because the 2 different oils are not mixing or agreeing
you thoughts would be appreciated
Cheers
Scolly
KDXer
Re: Full Syn and Semi Syn oil together? or mortal enemies?
Post by KDXer »
cfspawn wrote:could this be because the 2 different oils are not mixing or agreeing
Cheers
Scolly
ABSOLUTELY !!!
I had the exact same problem when I went from a semi to a full. I would drain it and use it for weed killer. :twisted:
cfspawn
Post by cfspawn »
thought as much. already kinda decided that was the case just wanted to throw it out there for sure
