High Idle
Motodeficient
High Idle
Post by Motodeficient »
I was riding today when all of the sudden my 220 started idling very high... When i pull the clutch in or when its in neutral. You can also feel it trying to rev too much when just driving when you aren't on the throttle... what could
cause this in the middle of riding?
I have done a little research which says this can be from a lean pilot jet. I guess this could explain why it didn't happen to the bike was fully warm? Maybe I will go from 42 pilot to 45
2001kdx
Post by 2001kdx »
Play with the air screw a bit. It is your best friend when you are displeased with your idle speed.
Motodeficient
I know i can adjust the air screw, but my question is what would cause me to go from a normal idle to a much higher idle in the middle of riding
Colorado Mike
Post by Colorado Mike »
Sounds more like an air leak. Check your carb to make sure all is well, especially the float level, then all the intake parts are sealing well. If that's all good, open the left cover and look around the the magneto to see if there is any oil in there. if so, your crank seal is toast. if the one on the other side is bad, it's harder to tell.
kelasaki
Post by kelasaki »
Just covering some bases. Were you about to hit reserve or run it out of gas?
Assuming there IS fuel available....
Motodeficient wrote:I know i can adjust the air screw, but my question is what would cause me to go from a normal idle to a much higher idle in the middle of riding
Air leak sounds good.
You might check the throttle cable retainer on the slide. Make sure the tab on the retainer is IN the slot on the retainer nut. If it's not...you will get erratic slide movement..thus erratic idle.
Sometimes you can feel that in the throttle..sometimes not.
Motodeficient
Yeah I'm thinking something with the carb/throttle as well, thats the only thing that would be moving like that while riding to cause this.
Motodeficient
Well I fixed it, I'm not sure exactly what caused it. I took the carb out, went up one size on pilot and main jets (its in the 60's anyway right now), cleaned/ re-oiled the airfilter, and reinstalled the carb. back to normal now. I've been getting the jetting down lately, maybe the carb wasn't seated in the intake boot properly or something. :rolleyes:
