Bike uneven drop in revs
Postby GhostRider » 12:19 am May 06 2007
Yet another question...
Took my bike out today with 5% toluene in my tank the response is great and the pull is great.
About 2 rides ago I had a new top end and I got the head modded. First ride out I experience this gung gung gung as the revs dropped. But the bike was running great so I ignored it.
Anyway today as the day went on and the temp of the air and the bike increased I think my response got not as good and it began to smoke more and the gung gung gung seemed to get worse it was doing it all the time (accept accelerating) even at idle.
What causes this uneven drop in revs and what is it? I believe it has got worse since running the toluene.
My jetting is a 155 main CGK needle #2 clip, 42 pilot with air screw out 0.75 turns.
I experimented with my air screw and found that the problem got a little better if I put the airscrew at 0.5 turns out but it made the response worse.
Please help im lost
**((Bike Profile))**
**((Bike Pics))**
I am a green machine (when im hungry) :lol:
GhostRider
Has thanked: 0 time
Been thanked: 0 time
Postby Indawoods » 06:59 am May 06 2007
What does your plug look like?
"People ate cows a thousand years ago for the same reason we eat them now. Cause they are easy to catch.We're not savages,we're´╗┐ just lazy. A cheetah could taste like chocolate heroin. But will never know. Those bastards are fast!!! "
Indawoods
Creator and Founder
Creator and Founder
Has thanked: 0 time
Been thanked: 19 times
Postby GhostRider » 02:23 pm May 06 2007
Ive done a plug chop with a 152 main jet and that is about right but I figured cause I ride alot of sand is better to be on the safe side with a 155 I know im rich but is that the problem or is it the needle or the pilot is it something else :shock: It doesnt return to idle very fast after blipping the throttle it does the uneven drop in revs and doesnt get back to idle to quickly. Ive heard this condition is from running to rich but if I turn the airscrew in even though it decreases response it mellows the problem and makes it slightly better. I do notice If I let the bike cool for 10 min still warmed up but just not as hot it doesnt do it as bad.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby Green Hornet » 07:15 pm May 06 2007
When you added the toluene, did you add it straight to your mix or did you figure it as a fuel & adjust from there. ie: 5 gal @40:1 + toluene or 5% toluene, plus gas equaling 5 gallons of fuel @ 40:1.. The sound you are describing sounds like a LEAN condition, is it a running out of gas sound or do I have the "gung gung gung" wrong.....
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Green Hornet
Has thanked: 0 time
Postby GhostRider » 11:37 pm May 06 2007
I worked the Toluene out at 5% of the Total Gasoline without oil then I worked the oil out. It could be running lean but with a CGK needle the richest pilot i've heard of people using is a 42 and my air screw fastest idle is around 1 turn out which I don't think is too bad. My needle clip is in the #2 clip which is also the richest clip i've heard anyone running a CGK needle uses. My main I know I am rich on but that is only about 1 size just to be safe for sand. How does toluene affect the jetting does it make it run richer or leaner? it seems the hotter the bike gets the worse it gets.
You don't think it could be something else (i.e the head mods or something engine related) do you.
It don't know what it really sounds like, but to me it sounds like it is actually having trouble to burn off excess fuel. But then that would not explain how turning in the air screw helps the problem but makes the response worse, or that its not spooging and that it's smoking alot. If I stop giving it throttle it tugs back and forward and makes a gung gung gung sound slowly dropping in revs. If I pull the clutch in it just makes the gung gung gung sound without the tugging.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby Jeb » 04:35 am May 07 2007
I wondering if you've developed a small air leak somewhere . . . double-check all of your intake connections
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
Jeb
Has thanked: 0 time
Postby GhostRider » 02:21 pm May 08 2007
Ill check for air leaks, but I actually think im 4 stroking.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby GhostRider » 02:41 am May 12 2007
Question for m0rie
Just wondering what position your air screw was in when you were running the CGK and what pilot you used to go with it thanks.
Im just wondering as ive got my needle in the #2 clip and the airscrew 0.75 turns out and excessive 4 stroking along with a slight bog just off idle. The problem is turning the air screw out to lean it makes the bog worse which I think is strange.
Im trying to solve the problem and im not sure whether to go left or right.
Your air screw position might gimme an idea.
Thanks m0rie
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Re: Bike uneven drop in revs
Postby KDXer » 09:04 am May 12 2007
GhostRider wrote:I got the head modded.
From where did you get your head mods ?? RB Designs ?? If so, forget I asked.
KDXer
Has thanked: 0 time
Postby GhostRider » 02:02 pm May 12 2007
Not from RB I would of liked to get it from RB but couldn't.
Wheres :prayer: m0rie, please answer my question.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby KDXer » 08:46 pm May 12 2007
Do you know what was actually done to the head ?? I'm just thinking it may be the cause of your problems. Have you tested with fresh fuel to eliminate that from the equation ??
Good luck... :partyman:
KDXer
Has thanked: 0 time
Postby GhostRider » 02:46 am May 13 2007
Me head was skimmed for more compression, im assuming the guy knew what he was doing as the last engine he did for me worked great, and he said he used to race an e series kdx so he knew how far to take it. I can only take his word for it.
The fuel was new as of last weekend when I rode it so it wasn't that.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby KDXer » 05:57 am May 13 2007
So just to clarify it was 4-stroking/surging without ANY tolulene added ??
KDXer
Has thanked: 0 time
Postby GhostRider » 02:33 pm May 13 2007
Yeah, It just felt like it got worse but I now think thats cause when I was going through trees at low speed. Ive heard it is normal that a bike should 4 stroke then, the only thing is mine was 4 stroking at idle quite badly.
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Postby m0rie » 10:48 am May 14 2007
I had it anywhere from 0.5 to 1.5 depending on the temp, altitude and weather conditions (foggy, clear, etc).
1989 KDX 200
2007 TTR-50E
m0rie
Has thanked: 0 time
Postby m0rie » 10:49 am May 14 2007
If you can post up some measurements of the head Ron might be able to roughly tell you if its been over done.
1989 KDX 200
2007 TTR-50E
m0rie
Has thanked: 0 time
Postby GhostRider » 02:03 pm May 14 2007
What measurements as in depth etc. If I do that I might do it next time my heads off for a service. In the mean time I might just play with my jetting. I could be wrong but I dont think its overdone or it would of been asking for some high octane fuel (pinging etc).
**((Bike Pics))**
GhostRider
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: Google [Bot] and 11 guests
