Tires
Posted: 09:18 pm May 03 2007
by Rick
Ok guys, I need a new rear for my kdx and my dr. Any suggestions? The kd has a Dunlop 737 110/100/18 and the dr has a kenda k778 120/90/18. Im not sure really how old either are, but the po of the dr said he replaced it recently (nov) an its shot. I like to ride all kinds of stuff, trails, some wet, some dry, and some hard mx tracks. I guess i need a medium tire. Any suggestions? Thanks, Rick
Posted: 09:46 pm May 03 2007
by thebleakness
Maxxis desert IT seems to hook up very well in just about anything I've ridden in. Abit pricey though...
I currently have a Kings on it and it's not bad but as soon as it rounds over the back end slides out like crazy. First ride or two was incredible though!
Posted: 09:55 pm May 03 2007
by Rick
Well, one of the places i ride has alot of (hard) spots. I probably need something on the more durable side. Dont need to go fish tailin that fast. Thanks
Posted: 10:22 pm May 03 2007
by Wazowski
I just recieved a Pirelli MT16 from Ebay...man is it aggresive looking. Good review on thumpertalk. I can't wait to try it out!
Posted: 07:32 am May 04 2007
by krazyinski
I am running a Pirelli MT16 works well but has no rim saver, also have a Maxxis IT and desert IT. these are my best tires for all around riding sand/mud/perfectloam/rock//hardpack. all of these conditions mix up, down here in south Texas. So far the Maxxis desert IT holds up the longest and is the best for running 10-12psi,and will not tear or chunk knobs. In about 3 months I will tell you how the MT16 holds up. the MT 16 tracks good in flat corners.
Posted: 10:29 am May 04 2007
by crf_kdx
I've had decent luck with the Maxxis Maxx Cross IT running terrain more or less similar to what we ran last Sunday up at Haspin. These tires seem to yield a reasonable value at RMMC prices. The Maxxis SI also is a decent tire although it costs just a bit more than the IT.
Posted: 10:39 am May 04 2007
by xagentman
Bang for your buck in my opinion is the Dunlop 952. great wear, good hook up in all conditions.. and cheap. best of luck.
Posted: 11:40 am May 04 2007
by 2001kdx
D756 is my favorite tire.
Posted: 03:17 pm May 04 2007
by motorider200
The maxxis IT and the terrain I ride in did not get along so well... The place I ride at often from lack of rain and heavy use form a layer of fine loose dirt up to about 3-4 inches deep in some areas and the IT had zero, none, no hook up what so ever in those areas. It made it so hard to accelerate out of corners. So i took that tire off with quite a bit of life left in it (about 3/4 of the tread left) and put on an IRC M5B which I am still running. The tire has great hook up and has worn pretty well, but I am missing like 32 knobbies
and there is still about 1/2 to 3/4 of the tread left. so I want be buying another one of those. I think I might try the Dunlop 952 next.
Posted: 03:23 pm May 04 2007
by GhostRider
I think the dunlop 756 is a good all round tire. But saying that if you ride lots of soft terrain i'd go 773 dunlop which lasted 6 months on the four stroke and provides great soft grip. Or maybe the dunlop 756 if you ride alot of variation, ive heard good things from the dunlops so thats just my opinion.
Posted: 03:32 pm May 04 2007
by kawagumby
I like the dunlop 739 110/100 as a good compromise tire for all kinds of terrain, wear is good, and it stays predictable.
Posted: 06:55 pm May 04 2007
by Jeb
I have the Pirelli MT-16 in the rear - 110/100. It hooks up quite well unless I'm in the worst of slop (then again what would) and the wear is great (no chunking, 'still got sharp edges after a few hundred miles). It's been working for me in conditions ranging from muddy uphills to mx track hardpack. Great "all-around" tire.
My next rear tire will be an MT-16 . . .
Posted: 04:47 pm May 09 2007
by jafo
I used to like Dunlops, but since getting into vintage MX, I love Kendas, preferably Milville intermediate terrain model. They don't last a long time but they have great traction all around. Alot of my buddies like the Track Master Series for price and longevity.
Posted: 07:34 pm May 09 2007
by KDXer
By far, the very best front and rears I have used are the Metzeler MC5 and MC6.
Posted: 08:00 pm May 09 2007
by marco220
I like the Metzeler MC4s for soft terrain. Stock front & 110/100 out back.
Posted: 07:28 am May 10 2007
by krazyinski
krazyinski wrote:I am running a Pirelli MT16 works well but has no rim saver, also have a Maxxis IT and desert IT. these are my best tires for all around riding sand/mud/perfectloam/rock//hardpack. all of these conditions mix up, down here in south Texas. So far the Maxxis desert IT holds up the longest and is the best for running 10-12psi,and will not tear or chunk knobs. In about 3 months I will tell you how the MT16 holds up. the MT 16 tracks good in flat corners.
I wanted to add after 200 miles the MT-16 is the best tire as far as traction goes, climbing deep V rutted washed out hills it will stick to the side of a deep rut going up hill with out falling in the rut.
If your running in multi terran like I do, the MT is showing wear a lot faster than the Maxxis desert IT after the same time period. I guess its the hard pack with shale rock that is hard on it.
Best traction MT-16 with good wear,great for all changing trail conditions.
Best wear and good to best traction Maxxis desert IT. good in most trail conditions, great in desert like conditions takes side wall hits from sharp rocks lugs will wear even all the way down if you turn the tire around at mid life. A good 6 month tire if riding every week at a A or B level.
Posted: 07:48 pm May 10 2007
by Rick
Thanks for all the input guys. I still havent decided!
Posted: 07:02 am May 11 2007
by krazyinski
Rick wrote:Thanks for all the input guys. I still havent decided!
buying a tire is like getting your hair cut, go to right place and it will be all good go to the wrong place and you look goofy for a while, in both cases it will grow back or fall out. then get to do it all over again.
tires are the same they wear out no mater how good or bad they are.
Posted: 09:12 pm May 11 2007
by Rick
Nice analagy! That helped....
