Just a couple of small questions on Toluene
Postby motofox2006 » 02:32 pm May 02 2007
Now ive finally found out where to get it from, it is time for me to mix up some toluene for this weekend my question is with Rons formula If I put 10% toluene to 4 litres how much kerosene? is 25mL fine. I worked out from Rons formula that kerosene is around 6% of toluene is that fine. You see I only want to add 10% not 25% And I cant get K1 kerosene,
Will plain kerosene work?
Why do the bums :butthead: on dirtrider say "hello to toluene goodbye to throttle response"?
And also ive read about octane boosters on other sights for 4 strokes they say to use oil??? why is this? I want too run dads bike on toluene aswell, will the benefits be the same in a four stroke.
E series 91 KDX
motofox2006
Has thanked: 0 time
Been thanked: 0 time
Re: Just a couple of small questions on Toluene
Postby 2001kdx » 05:28 pm May 02 2007
motofox2006 wrote:Why do the bums :butthead: on dirtrider say "hello to toluene goodbye to throttle response"?
Because they're Idiot bums and you should NEVER listen to those half-wits.
2001kdx
Has thanked: 0 time
Postby Mr. Wibbens » 07:12 pm May 02 2007
Why worry?
Try it and if you don't like it be done with it
I run it in my '92, 32oz's Toluene to 5 gallons premix, I skip the kerosene, so far so good :wink:
Mr. Wibbens
Has thanked: 0 time
Postby motofox2006 » 01:53 am May 03 2007
ok doky im going too run maybe 5% to 4 litres with 20mL of kerosene to be safe.
anyone know If I run toluene in a 4 stroke will the benefits be the same and will I have to use oil because ive read a few formula and they say you have to add oil??
E series 91 KDX
motofox2006
Has thanked: 0 time
Postby thebleakness » 02:02 am May 03 2007
2001kdx wrote:>|<>QBB<
Especially that 4thgearandpinned guy...
EDIT: Oh wait! It seems as if he's banned? Now what would he do to deserve that sort of punishment? :butthead:
thebleakness
Has thanked: 0 time
Postby GhostRider » 02:06 am May 03 2007
:butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead: :butthead:
HEHEHE 24 bum salute
**((Bike Profile))**
**((Bike Pics))**
I am a green machine (when im hungry) :lol:
GhostRider
Has thanked: 0 time
Postby motofox2006 » 03:26 am May 03 2007
Will plain kerosene work please let me know cause I was informed K1 was the right kerosene but I can only get plain kerosene.
E series 91 KDX
motofox2006
Has thanked: 0 time
Postby canyncarvr » 11:31 am May 10 2007
You don't have a hardware store of any kind where you live? K1 grade kero isn't a rarity...it's everywhere. How about a heating oil outfit?
Q: How is K1 kerosene different from other types of kerosene?
K1 is the safest type of kerosene. Other grades contain more sulfur and produce emissions that can endanger your health.
From: http://www.carrollfuel.com/residential/faq-kerosene.php
No...the 'health' part isn't the point.
BTW, 32oz. is 5% of 5gal. Using percentages is a lot easier when applying a volume of something across different measurement systems...English and metric for example.
Images: 26
Has thanked: 0 time
Been thanked: 2 times
Postby motofox2006 » 02:42 pm May 10 2007
In my country I am limited I can only buy Kerosene, theres no K1 or K2 grade. What I do know is that the stuff im using Is clear blue colour that I bought from the local hardware place, is this stuff allright? Im only running 5% so should I start skipping the kerosene or should I just burn what ive got.
E series 91 KDX
motofox2006
Has thanked: 0 time
Postby canyncarvr » 03:07 pm May 10 2007
Kero is differently dyed in different places to mark it as having been determined for different uses. At least up here.
Off road (or diesel bought with a commercial permit) is much cheaper than fuel bought for use by one-each drivers. Why not spend a LOT less and fuel up with 'off-road' stuff in your ON-road vehicle? Because when you get 'dipped' (the word used to mean 'tested') by a cop that stops you and happens to want to bug you about it, you had better have the correctly colored stuff in your fuel tank!!
That doesn't matter in regard to this..but another btw..
Blue doesn't matter.
Ron's brew has a bit less than a litre of toluene in one US gallon (200ml or so short of four litres). That's 20%! Hence the kero add.
I've run toluene for a couple of years now..at a 5% rate...don't use any kero..don't have/hadn't had any problems, either.
Use the kero or not? Don't have to..can if you want to.
Images: 26
Has thanked: 0 time
Postby 2001kdx » 03:19 pm May 10 2007
thebleakness wrote:>|<>QBB<
They wrongfully banned that 4thgearandpinned guy. He did nothing wrong. except for bash those admins...
2001kdx
Has thanked: 0 time
Postby motofox2006 » 11:02 pm May 10 2007
At the moment im adding kerosene which is 6% of toluene, so ideally should I skip the kerosene cause its really unsafe i.e if I keep using it would I maybe start to grow a third leg. :wink:
I know alot of you guys who use toluene dont use kerosene but im afraid of seizing it because ive heard if you use toluene as an additive it can wash the lubrication off moving parts.
Do you mind me asking if you hammer your bike Wibbs and CC because I do and im just so cautious about seizing the engine if I don't use kerosene, am I over concerned.
E series 91 KDX
motofox2006
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: Google [Bot] and 10 guests
