Problems with bike
2001kdx
Problems with bike
Post by 2001kdx »
I've been riding lately and noticing that my bike will, every once in a while, fail to gain RPM's. It will just barely even rev, and will be needed to be cleaned out in a higher gear. I think it's the powervalves. Does this mean I must pull the cylinder off the bike? exactly what gaskets and other stuff is needed for I guess would be just a powervalve clean?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
All you really need is a head gasket if you are careful. And just pull the head... everything can be accessed from there.... :grin:
2001kdx
Post by 2001kdx »
That doesn;t sound too bad, Now I just hope it will cure my problem.
2001kdx
Post by 2001kdx »
If I were to open the cover and turn it manually, it would not open when the bike is cold right? That is if I turn it when it's running? Sorry, still confusedk, I'll keep seaching.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Upon inspection, pull the left side cover.... start the bike. Let it warm up 'cause she won't rev smoothly until that happens, then rev it to around 6K and see if it turns... if it does... then the KIPS is probably activating... doesn't mean all parts are operating but it means the shaft is turning when it should.... everything else requires you pulling the head...
