Torque settings
motofox2006
Torque settings
Post by motofox2006 »
The time has come to torque my head and cylinder does somone have the torque settings, thanks. Mines a 200
E series 91 KDX
xagentman
Post by xagentman »
they are in the book if you have it. I dont have mine at work or i would give them too you.
==05 KDX220R==
motofox2006
They are probably in the book but me dont have book if you gimme the torque setting when you get home that would much appreciated thanks.
E series 91 KDX
marco220
Post by marco220 »
Cylinder Head Nuts 18 ft/lb
Cylinder Nuts 18 ft/lb
Engine Mounting Nuts 33 ft/lb
Engine Mounting Bracket Bolts 22 ft/lb
2002 KDX 220
RB'd Carb and Head
I don't crash often... but when I do, I'm going for style points!
canyncarvr
Post by canyncarvr »
Hard to get to the cylinder nuts without an adapter. MotionPro makes one. No need to figure torque value differences as long as you keep the adapter at 90º to your torque wrench.
xagentman
Post by xagentman »
I just removed the tank. its 2 screws and a rubber strap. :wink:
==05 KDX220R==
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That works for the head bolts but not the cylinder bolts. :wink:
canyncarvr
xagentman wrote:I just removed the tank. its 2 screws and a rubber strap. :wink:
:hmm:
I will assume there is a meaning to this that I am too dense to understand.
Rephrase, please?
What do the tank, two screws and a rubber strap have to do with access to the cylinder nuts with a torque implement?
Thanks.
xagentman
Post by xagentman »
disreguard. I need to "read" and not skim the post. *sigh* :roll:
==05 KDX220R==
canyncarvr
No problem.
I've been guilty more'n once of missing something as plain as the nose on my face. Why then assume it's NOT my misunderstanding?
Cheers!
