Bike shuts down after riding for 10 min.
Posted: 09:20 am Mar 19 2007
by fly11269
2002 stock KDX 200
I start the bike and let it warm up then ride for about 10 minutes and it just bogs down and shuts off. Sounds like its starving for fuel. The only way it will start again is if I put a clean plug in it. The plug I pull out does not look that bad and its not wet with spoonge. Could it be over heating? How do you tell?
I checked and cleaned the carb (carb looked new) drained the tank and put fresh fuel.
Posted: 09:26 am Mar 19 2007
by Indawoods
Check for clogged jets!
Posted: 09:34 am Mar 19 2007
by IdahoCharley
Make sure gas tank is vented.
Posted: 10:00 am Mar 19 2007
by fly11269
pulled the jets out and they are clear.
Posted: 10:09 am Mar 19 2007
by fly11269
IdahoCharley wrote:Make sure gas tank is vented.
I pulled the vent line out of the stearing tube and the end of it was wet. Looks like there is water in there
. You think this could be the problem?
Posted: 10:12 am Mar 19 2007
by m0rie
If you've got water in your gas it could be stopping the float bowl from filling up correctly. Drain you tank and float bowl and refill with fresh premix and a new plug. Also check your float level.
Posted: 10:25 am Mar 19 2007
by KDXer
I had a simlar problem on a 2000 DT175. The stupid keylock on the gas cap wasn't water tight and after a bit of rain the same thing would happen and it would slutter and die. Does it happen consistantly after 10 mins because the DT would die sometimes after 1 minute or sometimes after 10 or more, never consistant ??
Posted: 10:33 am Mar 19 2007
by fly11269
m0rie wrote:If you've got water in your gas it could be stopping the float bowl from filling up correctly. Drain you tank and float bowl and refill with fresh premix and a new plug. Also check your float level.
Pulled the bowl off and there is no water. Drained the fuel tank in a bucket and no water in there either. Wondering if the water in the stearing stem just would not let air in the tank causing the fuel not to get to the carb?
Posted: 12:39 pm Mar 19 2007
by GS
That vent pipe blockage would be a good bet....the 10 min run time being a good clue. Simple thing to test, too !
Let us know!!
Posted: 05:05 pm Mar 19 2007
by KarlP
I had an old Honda years ago that was equipped with a dissolving fuel line. I never saw anything like it. I think it was surgical tubing. Anyway, it swelled up big as a sausage, put all kinds of goo in the carb and would not run for long. Took forever to clean that situation up.
I doubt that is your problem, just brought back a memory.
When you say put a clean plug in, do you mean a new plug, or one you pulled previously and cleaned up? If that is the case, next time it dies, don't change the plug, just let it sit for the amount of time it takes you to change a plug and see if it then runs. Know what I'm getting at?
I'd be inclined to suspect a tank venting issue. Easy enough to check, ride around with the gas cap off!!
((Caution: Gas on the pants causes a burning sensation to those areas in the pants))
Posted: 09:04 am Mar 25 2007
by fly11269
I ran the bike today and it did the same thing. I think the float may be getting stuck (it was peeing when stalled). Where can I get a new float and jets off the net?
I just installed a REV pipe and powercore II and opened the air box. What jetting do you guys recomend?
Posted: 10:20 am Mar 25 2007
by Indawoods
I would think an adjustment should do it....
