Shock brackets on a 93 KDX200
vinny
Post by vinny »
The brackets that mount the uni-trac linkage to the frame and also mounts between the swing arm and engine. Will these interchange with a KX of similer years? What the deal is is that I have one that needs replacing (long story) I have found one that goes on a 94-96 KX125/250 but I can't find the part number to see if its the same. The part I need is 32037. I have looked at a few schematics but I cant find the KX part.
Thanks
Vinny
tim
Post by tim »
06 200H
GALLERY!
vinny
Post by vinny »
That picture doesn't show the brackets I'm talking about. I can't seem to find it in the KX schematics anywhere. Under the KDX schematics its listed under Frame fittings or frame fittments. Something like that. There are 2 of them, left and right. One shaped different than the other. The linkage itself accually bolts to them and that is what holds the linkage to the frame
Vinny
quailchaser
Post by quailchaser »
1993 KDX 200
32037-1535 left side
32037-1536 Right side
The reason you can't find this for the 94-96 KX 125/250 is that it is part of the frame for those years.
The KX 125/250 J series has those brackets (1992-1993)
KX125/250
32037-1581 LH
32037-1582 RH
So does the H series (1990-1991)
KX125/250
32037-1522 left
32037-1523 right
So does the G series (1989)
KX125 G 1989
32037-1529 left
32037-1530 right
KX250 1989
32037-1495 LH
32037-1496 RH
F series 1988
32037-1461 LH
32037-1462 RH
E2 KX125 & E1 KX250 (1987)
32037-1420 LH
32037-1421 RH
All the brackets look similiar in the diagram...but, they all have different part numbers.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
vinny
Post by vinny »
Thanks Quailchaser! I wonder what the last four numbers designate? The guy selling the linkage and brackets mistakenly told me they would fit 94-96 KX 125/250. No wonder I couldn't find them.
Vinny
quailchaser
vinny wrote: I wonder what the last four numbers designate?
The first part of the number (the stuff before the -) is how KAW categorizes the part. The second part of the number (the stuff after the - ) designates the specific part in that category for a given application.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
