Shock brackets on a 93 KDX200
Posted: 09:17 am Mar 08 2007
by vinny
The brackets that mount the uni-trac linkage to the frame and also mounts between the swing arm and engine. Will these interchange with a KX of similer years? What the deal is is that I have one that needs replacing (long story) I have found one that goes on a 94-96 KX125/250 but I can't find the part number to see if its the same. The part I need is 32037. I have looked at a few schematics but I cant find the KX part.
Thanks
Vinny
Posted: 06:21 pm Mar 08 2007
by tim
Posted: 07:20 pm Mar 08 2007
by vinny
That picture doesn't show the brackets I'm talking about. I can't seem to find it in the KX schematics anywhere. Under the KDX schematics its listed under Frame fittings or frame fittments. Something like that. There are 2 of them, left and right. One shaped different than the other. The linkage itself accually bolts to them and that is what holds the linkage to the frame
Vinny
Posted: 11:49 pm Mar 08 2007
by quailchaser
1993 KDX 200
32037-1535 left side
32037-1536 Right side
The reason you can't find this for the 94-96 KX 125/250 is that it is part of the frame for those years.
The KX 125/250 J series has those brackets (1992-1993)
KX125/250
32037-1581 LH
32037-1582 RH
So does the H series (1990-1991)
KX125/250
32037-1522 left
32037-1523 right
So does the G series (1989)
KX125 G 1989
32037-1529 left
32037-1530 right
KX250 1989
32037-1495 LH
32037-1496 RH
F series 1988
32037-1461 LH
32037-1462 RH
E2 KX125 & E1 KX250 (1987)
32037-1420 LH
32037-1421 RH
All the brackets look similiar in the diagram...but, they all have different part numbers.
Posted: 08:48 am Mar 09 2007
by vinny
Thanks Quailchaser! I wonder what the last four numbers designate? The guy selling the linkage and brackets mistakenly told me they would fit 94-96 KX 125/250. No wonder I couldn't find them.
Vinny
Posted: 10:37 am Mar 09 2007
by quailchaser
vinny wrote: I wonder what the last four numbers designate?
The first part of the number (the stuff before the -) is how KAW categorizes the part. The second part of the number (the stuff after the - ) designates the specific part in that category for a given application.
