Has anyone used the Probend pack with the triple clamp mounting method after a KX fork conversion?
My old setup; Fredette barkbusters with Cycra triple clamp mounting bracket connected to KDX upper clamp with bolts through the FRONT of the clamp.
I was thinking of ordering a set of Cycras and I already have the triple clamp mounting brackets, but it isn't clear to me how they will work since the KX upper triple clamp bolts come in through the BACK (instead of from the front as on the old KDX triple clamp).
I'm confused. Please help!
Cycra handguards after KX fork conversion
- wanaride
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
2006 KTM 250XCW
2003 KDX200
2006 CRF70
Re: Cycra handguards after KX fork conversion
I think you are going to have to go this route:wanaride wrote:Has anyone used the Probend pack with the triple clamp mounting method after a KX fork conversion?
http://www.cycraracing.com/techtips.html
The TC mounts won't work on the rear side of the TC. On another note, I would buy your TC mounts from you when you are have figured out your new mounting setup. I need to connect Cycra Probends to the stock KDX TC on my wife's new 220.
- krazyinski
Cycra triple mounts wont work for you on those forks or that triple clamp.
you dont want to do it any way. I just installed the triple mounts on mine and I get a lot more vibration in the bars than before.
- wanaride
- skipro3
- wanaride
Jerry, thanks for trying, but isn't that an aftermarket upper triple clamp with side mounting bolts?? The stock KX upper triple clamp bolts mount from the back, thus I can't see a way for your solution to work on my bike.
And while trying to bend my old Fredette BBs to make them fit my new setup, I actually broke one of the aluminum BBs. Now I have to buy new ones anyhow. Crap!
Any other ideas??
Any other ideas??
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 250XCW
2003 KDX200
2006 CRF70
- skipro3
oh, you must have '03 or newer triple clamp then? This has been discussed in another thread about a year ago I think. heck! You even participated in that thread!
Click This
Click This
- wanaride
Yes I did. (I even brought it back to life!) After seeing your post I re-read that older thread last night, and Colorado Mike seems to have confirmed it; no Cycra triple clamp mounting on a KX triple clamp ('03 and newer, mine is '04).
I'll just plan to get some D-Flex guards from Rocky Mtn.
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 250XCW
2003 KDX200
2006 CRF70
