Devol front disc guard
- jsherm01
My bike came with one of these. When I tried to mount the front wheel without it I had clearance problems with the disc on the caliper and the hub to fork leg - too tight! Do these come with a shorter axle collar since the guard itself is quite thick aluminum?
I have no idea..but I'm sure Devol would know.
Devol:
Phone: 360.825.2106 - Fax: 360.825.2663
Email:
customerservice@devolracing.com
They only list one application...so I guess the year of your bike won't matter...unless it's NOT in the application list!
KDX 200/220 1994-2007 KD-0010 Front Disc Guard $57.00
I don't have one..it has a mounting method that looks to include a change to spacer width? It has it's own? Guess that would be the easiest way to mount one of 'em.
Looks like it:
If no one here has the answer hopefully Devol will help you out.
Good luck!
Devol:
Email:
Looks like it:
Good luck!
What year bike do you have?
Somewhat BTW..but I gather you want to remove the guard?
Why is that? (another question I have an answer for..but asked in such a way as to illicit information..I'm such a PITA!)
With dimensions, you could get one made without too much trouble or expense.
Although...I'm not sure why it's even a question...
You can get the part from RonAyers for less than $7 PN 92027-1959.
DO take a good look (imo) at the parts breakdown to make sure you have every other piece that may have been removed/changed during the guard install...washers and stuff.
92027A... 92027-1959.... COLLAR L=12
