Correct amount of oil?
SteveWR450f
Post by SteveWR450f »
New to KDX. Have brand new 04 220. Engine is a little noisey but heard that KPS is known to make noise.
Read on Thumpertalk that some people recommend adding additional oil to quiet down the engine
Thought I would ask the gods here on this site because you guys know the most about the KDX.
Thanks for your time.
grump99
Post by grump99 »
Yep 1 full quart will help the noise and won't hurt your tranny. I use Valvoline 10-40, but any decent brand will be fine.
skipro3
Post by skipro3 »
Sounds like good advice so far. Just don't use synth's that have friction modifiers. Check the lable on the oil container. Also, do a search here as there's lots of good info and opinions on oil types.
KarlP
Post by KarlP »
The best, and only, oil to use is Castrol 20w-50. One full quart.
The best, and only, premix oil to use is Golden Spectro mixed at 42:1.
:lol:
Just trying to cause trouble.
SteveWR450f
Thanks guys. I will try a full quart. I am using Shell Rotella T - dino. Have a rekluse clutch in my WR450 and the oil is cheap and seems to be working good. I change oil frequently. After every 2 - 3 rides.
Steve
WR sold. Now have 03 and 04 KDX 220s.
KXF 250 forks. RB Carb and Head. FMF rev pipe. Long live the KDX !!!
Not only no synth..but nothing dino with friction modifiers in it, either. If it is labeled 'Improves mileage' or some such, it is NOT for a wet clutch.
ANY motor oil approved for wet clutch applications is fine.
Some run ATF. Some like that some don't. IF I was running ATF I'd use a Ford type (organic clutches)...but I don't.
It's not the KIPS that makes the noise..it's the clutch. Notice how things quiet down in neutral when you pull the clutch lever.....
Anecdotal and all, but I use a full quart for an oil change, but 1-150ml or so of that is a chaser I dump in before putting the drain plug back in. Sort of a 'rinse' if you will.
Your next question: 'How come I can't push my bike in gear with the engine off and the clutch pulled without skidding the back tire?'
Because it's a KDX.
Don't pay attention to KarlP...he's an old 450 4T rider.
....oh........... :neutral:
