Too much off track going on here.....
Again...no need to get ANAL about it. The KDX (or any other 2T) is not
fragile..you need to use some common sense is all.
A few things:
The pilot circuit certainly flows fuel with the throttle closed. Not enough to 'feed' an engine spinning 8000RPM that is already hotter'n hell from pulling 6th gear at the speeds I used for example.
Re: 'so I should avoid using the engine to help controll my speed while going down hills?'
No. You should not
avoid using engine braking. Although...the whole idea of compression braking on a 2T is pretty much a joke to start with.
Re: 'And then sometime killing the engine if the timing with the clutch is not correct.'
The man's name is Chuck Steahly. He owns Steahly Off-Road. Get a FWW.
Re: 'Hows about just opening the throttle up a few times on a downhill..'
Again...I'm not talking about a need to blip the throttle to keep things from sticking when you're going downhill.
Again, I'm talking about a situation where the bike is VERY hot..and has been straining against its leash for a LONG time..WOT and every hair on every pony is trying to go as faster as it can go. A situation where, if you completely stopped, the bike would be smokin', the pipe would be cracklin', and the exhaust would likely be voluminous (that means 'a lot') due to carbon burnoff in the pipe from the heat. If you have a fiberglas pipe guard..you're going to be smelling a LOT of that!!
In
that sort of situation, rolling the throttle down when you're spinning 9-10K+RPM and moving close to 80mph is the
most likely place a lean-roll seizure is going to happen.
Yeah..most of the above a repeat..but my original scenario was being ignored. I'm not referring to long downhills in the trail riding sense. Well...if you ride those tracks in 6th WOT for minutes at a time, I am.
Jeb: Re: Everything you said.
I don't know that some other oil would have made a difference. I do know I had been running SuperM and had never paid express attention to nit-picky throttle control. I tried the BelRay product just to try it. My bike was fairly new at the time..certainly broken in. I'm saying it wasn't overdue for a top-end, wasn't running with a top-end I had just put in that had some problem, it was the Kaw OEM bike.
It falls under the heading of, 'Screw me once, shame on you, screw me twice, shame on me.' There was NO reason for my bike to have stuck when it did. Yeah..it was a lean roll throttle situation, not nearly as severe as the sort of 'example' I have used. It was no different than any other throttle situation I've done a brazillion times before and since. The one thing different? The oil I was using..and that was BelRay HR1. I don't need it to happen twice to know I'll never use it again.
No, I don't care to hear how famously perfect it works for someone else. You're welcome to run it if you wanna.
I'm welcome to not.
The BelRay part is NOT the reason to avoid lean roll throttle events. Lean rolls are simply known to be problematic...for obvious and easily understood reasons.
