. . . a bit of a fitment issue. I didn't recognize the difference between these and m0rie's '02 KX250 pegs but there is. Here's a mini-pic comparing my 220's peg and the '01 KX peg . . .
At first I thought they were the wrong pegs but, indeed, these ARE '01 KX250 pegs per buykawasaki.com . . .
so here's what I did: cut the piece of thin flat between the two "hinges" on the KX pegs so I could stagger-mount them. I used the KDX springs and the KX pin (had to in each case). I ended up fitting three 3/8 SAE steel washers so that the peg hinge that fits between the KDX frame peg mount rested on them - this was necessary to keep the cotter pin hole clear (also snugged things up between the KDX peg mount hinges.
Go here to see more and bigger pictures.
One concern for me. Note how the first coil on the spring overlaps the end of the pin. I've got about the same tension on the coil and the peg rotates up OK just like the stockers.
What do you think? I'm thinking a crash violent enough to get the spring to pop off would likely do so anyway, but I'm not sure. Anybody do anything like this with pegs?
Overall the pegs are pretty cool - certainly feels like a more solid, secure footing.
I believe I got away with learning a lesson without suffering too much!
'01 KX250 Pegs: Uh Oh . . .
- Jeb
- Jeb
- quailchaser
Hmmm. Those look like the '99-01 KX or ‘03-04 KX pegs.
From Kawasaki…’99-01
Here is what Kawasaki shows for the ’02 KX.
Here are the ones off my ’02 KX.
Here is what they show for “03-04
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- Rick
I wouldnt worry too much about the springs. They might wear eventually, and that part of the spring could pop onto the outside of the pin. The one thing i would worry about, is hitting something straight on. The way that peg is sitting in the bracket, it might be more apted to break the actual bracket, than the peg if you hit something real solid, and they dont flip up. Probably a one in a thousand chance though. They look good!
Yes, they really do let me drive the Train!
1991 KDX 250 $Sold but not forgotten....
1996 Suzuki DR 350 $Sold!
2002 Honda CR 250 worth more than my house at this point........ :-)
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
The 02's are the ones you want if you can find them....
In the 'from the top' pic.....they look to be at angles..not straight to the bike? Are they?
- Jeb
Yeah, they're angled back a tad . . . do you think that'd be a problem?canyncarvr wrote:In the 'from the top' pic.....they look to be at angles..not straight to the bike? Are they?
I rode for a few minutes late this morning - awfully cold for it but I wanted to see what they felt like. The pegs are a shade lower and back - not much - but in a different spot, < 1/2" in each of those directions. I could feel a bit more room 'cause my new, stiff mx boots seemed to deal with upshifting better. It felt like they had been moved more than they were. Obviously, it also feels like there's more peg.
Over time I'll be able to tell how it impacts handling if any, but right now everything seems OK.
