I have a 94 kdx with the stock usds and they are way to soft even with a spacer in there, mx tech has a spring catolog by size as in width x height
Does any one have a clue of the size, or other model springs i can run?
thank in advanced
-luke
What size fork springs?
- radonc73
Yep.
The RT site will list the spring series for your bike. You can look for that same spring series used in other bikes.
The answer to your question: No. I don't know what other model springs you can use for a 94kdx.
**edit**
I just looked. The spring series used in your bike is:
FRSP 3647
What do later (like mine..an '00 'H' model) use?
FRSP 3647
So...you can use any spring for any later model 200/220.
Does that answer your question?
RT says your bike came with a .29 spring, btw. Gee..the weenie springs in the the newer 'H' models are .35s!!
**edit**
FRSP 3647
FRSP 3647
