gearing
Posted: 11:01 am Dec 11 2006
by Sky.A
A friend of mine said that dropping teeth on the front sprocket as opposed to adding teeth on the rear to gear it down will make my bike rev out quicker. is this true? or should I opt for the stock front and larger rear currently have 12/50 on my bike and down here it 1st is still way to low and second is just a tad bit too high. but its way better then stock any input will be helpful TIA
Posted: 11:35 am Dec 11 2006
by Indawoods
Your ratio is lower than anyone elses right now I believe. a 12/50 is LOW!
I don't think you can go lower in the front anyway.....
Posted: 02:09 pm Dec 11 2006
by krazyinski
the trouble with dropping the front as low as you have and raising the rear is what you have. ratio is way off. try going up on the front 1 then down on the back 1. then if 2nd is to high with youre curent gearing, you could be suffering from power problems not gearing.
Posted: 08:00 pm Dec 11 2006
by canyncarvr
Curious..how is a ratio 'off'? You're referring to chain angles or something?
You're saying a 12/47 is somehow largely different' from a 13/50?
This part:
..is right on the money.
I don't know why you would want, and what good a 12/50 would be.
Allowing the engine to PULL against a gear is often a good thing. A bike that is running correctly and running against a bit too HIGH a gear will likely work much better than the same bike geared low. The low gear allows for a quick wheel-spin situation..and when that happens, you aren't going anywhere.
Posted: 08:40 pm Dec 11 2006
by 2001kdx
I was actually thinking of running 14/47 when i get my woods pipe, that way i have a bit less wheelspin in the swampy areas, and a bit more top end pull on the fire roads and fields. What do you guys think i have to gain with a tooth extra bigger cs? For the record ive tried 12/47 and it made first gear useless. or at least more useless than it is now.
Posted: 08:50 pm Dec 11 2006
by Colorado Mike
I run a 12/47 on my 220 torque meister, and 1st gear is still very useful. maybe you don't need to manuever big rocks and stuff though.
Posted: 09:18 pm Dec 11 2006
by AZRickD
I'm running 13/50 with 110 tires. I can't imagine first gear being any lower and at times think about going to a taller ratio by dropping the rear to a 49 or 48. The 13/50 is great in rocks, though.
I also can't imagine second gear being too high with that ratio.
Rick
