JETTING FOR COLD DESERT RIDING?
Duke
Post by Duke »
Current specs are 155/45, resulting in good performance, nice brown colored plug and acceptable spooge emission. However, these symptoms were found in 68 degree plus weather. Now I plan on a venture to the desert this weekend and the temps are expected to be around 38-45 degrees. Since a large portion of the time will be spent traversing steep hills and sand washes, read wide open much of the time, I am considering the use of stock OEM jetting specs. Any comments?
bradf
Post by bradf »
The 20 degree temp change warrants the next size up to 158 and the sand conditions would probably need a 160.
m0rie
Post by m0rie »
I'd second bradf's suggestion. OEM jetting is rich enough to handle WOT in the desert as long as your not in Death Valley. Your fuel mileage will however suck. I wouldn't plan on more than 40mi from the tank.
Rhodester
Post by Rhodester »
My 200H (RB,VF3,-35,Q,etc.) would need a 162 at those temps and at 2500' in the desert. A 160 would be risky crisp jetting in the upper 30s and low 40s (on MY bike).
'95 200H
IdahoCharley
Post by IdahoCharley »
Take a few mains with you!
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
