...go with the large diameter Q needle and pick a taper that starts later, such as a CEQ or DEQ..
RE... I don't think so. You take into account the large difference in L1...where? There are two clips worth to be figured, and that matters. Obviously you can move the clip, but that wasn't mentioned.
gee, I always thought that the steeper the taper, the later the taper will start on the needle. Like the post:
RE... it's a taper thing, mostly. The 'C' being steeper angle-wise (changes diameter faster when the taper starts) it starts taperling later (farther down) the needle than does a 'B' needle. 11/8/06
That was my comparison to the stock BEQ vs. the CEQ or even the DEQ. But yeah, officially, the start of the taper would be even later on a CGQ or DGQ series. The difference in L1 as argued above is not an official one, but more of the thought that the taper starts later on the C and D and E series than starts on a B. Clips 3 and 4 are the only two that matter, I agree.
RE... A DEQ IS MORE lean than an R1174N, but not for very long. Less than 1/4 throttle and it's considerably more rich (for example..same clip).
I was comparing the DEQ to the R1174"K" that came out of my 200. the K taper would be an "F", in between E and G on the three letter conversion chart. So, stock 200 = BFQ.. An average between 38.15,E and 39.95,G is 39.05, F... If the L1 on the BFQ is even longer than a E L1 of what is generally recommended ie CEL, etc, then how come the B taper makes these bikes a blubber machine off the bottom?
answer: re.. Now you can see why different taper angles matter so much..the taper starts in different places on the needle (with a given L1 and diameter).
Call it CGQ and definately DGQ for a later start to the taper. I can see that because the "N" has a longer L1 stock for the 220, I am assuming that needle is stock, then the CEQ is equal or shorter than the stock N needle.
re.. Try some toluene! You'll like it!!
No thanks, I need to keep all of brain cells I have!!
Its all fun and games until someone's eye gets poked out!!
Yes, the EEL needle is working great in the carb, even with the RB mod. It is electric, and it does float the boat. The steep taper takes the slight bog away from running no airbox lid.
Still running the same spark plug from 4 months ago, when I installed the RB carb.
