Real hard time Starting
- Ryan
I am pretty sure it is due to jetting but my bike is having a really hard time starting. The weather is about 40 degrees. I used to be able to start it, in like 1 or 2 kicks cold when it was about 70. Now it takes 30 or 40 kicks and by the time is starts i have to rest. It runs great once it warms up. When it is warm, one kick gets it going.
2001 kdx220
1987 honda xl250
1987 honda xl250
- m0rie
Turn the air screw in all the ways and make sure the choke is on before starting it.
- bradf
I change my pilot at 30 degree change. I use a 40 for over 50 degrees and a 42 under 50. It is quite possible that a change is needed. Also, the very rich condition present when the starter valve is raised makes it harder for the spark. So there could be a problem there like a weak spark or a plug/gap.
- Ryan
- bradf
Basically, your pre-mix ratio has diddle to do with it, or very little diddle. Anytime you pull up on that enrichening circuit it becomes VERY rich, just like a choke condition. Check for a good blue/white spark, proper gap and float level. The enrichening circuit could be plugged or partially blocked. If that's the case the plug won't be fouled. That would require a good cleaning out. The AS should already be where it always was, but check it again. Try Morie's suggestion to make it even richer. If yer fouling the plug it could be a weak spark.
- Colorado Mike
- Mr. Wibbens
How's your fuel?
A little water in the bowl will make for hard starts and it'll stay there until you drain it
- Ryan
its pretty fresh. This has happened more than once though, so i think it is definatley to do with the cold. I will try to put my 45 pilot in. Thanks for all your help guys, you all answer pretty quick and you always know the answers to my most of the time not so smart or thought through questions. .
2001 kdx220
1987 honda xl250
1987 honda xl250
I had a similar problem with my YZ250 -- sometimes it would start 2-3 kicks others it would take 1/2 of my riding time -- it didn't matter if the temp was 20 degrees or 90 degrees. I tried everything mentioned above and nothing made a difference.
The problem turned out to be the kill switch! It was intermittently sticking part of the way in. Swapped it and it never failed to start by the 3rd kick.
Just thought I'd mention it....
2002 KDX 220
RB'd Carb and Head
I don't crash often... but when I do, I'm going for style points!
RB'd Carb and Head
- Mr. Wibbens
Fresh really means little (well unless you buy Arco gas). My bike sat for a year and a half with the same old gas in it. I kicked it 20 times, nothing. Drained the bowl and she fired on the second kick.Ryan wrote:its pretty fresh. This has happened more than once though, so i think it is definatley to do with the cold. I will try to put my 45 pilot in. Thanks for all your help guys, you all answer pretty quick and you always know the answers to my most of the time not so smart or thought through questions. .
I've got six bikes out in the shed, any of them give me trouble starting, first thing I go after is the carb, take it off & clean it, and they always fire back up really easy
re: 'so basically it is just way rich.'
IF it was right, and the weather is colder, it's too LEAN, not 'way rich'.
A .032"+ plug will give you fits starting.
If your start method doesn't work, change it.
Do what m0rie said, for one.
Before you try to fire it, kick it a few times while holding the kill button 'on' (in).
By listening and paying attention to the bike, you will know when it's not starting due to too rich or not rich enough (that a reference to the intake charge, not jetting). Change that situation with throttle position, sometimes laying the bike on its side to clear an overfull carb.
Lots of tricks and methods. Find one that works and use it.
Change your pilot as already mentioned.
The point of jetting is to make the bike run well where you USE it..and that is likely when it's hot. I'll hassle with a cold-blooded starter when I know it RUNS great once I GET it running.
Fact is, a properly jetted KDX starts easily AND runs well with the same jetset. If you're having a problem, you need to change your jetting or your choke-cold start method.
