Will the works connection radiator braces will fit if we install a IMS high capacity desert tank on a 2001 kdx220?
thanks a lot
IMS tank 1996-and more fittement?
- kdxquebec
- kdxquebec
If the OEM shrouds fit on an IMS (or any other) tank, the braces should fit as well.
I'll bet MY Works braces wouldn't fit!
As bent up as they are, I'm sure they won't fit back ON an OEM tank next time I take'm off!
KDXQ: Please drop a note about the fit on your bike!
Thanks!
Thanks!
The Works Connection pieces are braces.
The MSR (and similar Devol) pieces are guards.
..btw and all........
«the guards for a frontal impact, right? »
It protects against the branchs and the boulder too because they can't penetrate the radiator.
But the side Works Connection helps againts a crush radiator when the bike fall.
canyncarvr, sorry for the mistake, I speak french normally and I try to write very well here.
