Hey all.
Just wondering If anyone has had experiences with MCS gear levers. mines busted and looking to be replaced they are quiet cheap compared to OEM and also other brands. i have also been told they are steel any comments would be appreciated.
Gear Levers.
- cfspawn
- cfspawn
- cfspawn
- krazyinski
my OEM broke the spline clamp, is this normal ?
- cfspawn
- krazyinski
what I did was went and purchased a cheap lever MSR like and cut the spline clamp off of the oem and the new one and welded the new clamp on the old shifter. just use a bolt and two washers to protect the splines from slag, the oem bolt will hold it in the right spot then weld away.
