Moose complete gasket set?
- TopperHarley
I just opened up a Moose complete gasket for 95-05KDX220R. appears that ther is only one KIPS main shaft oil seal and no little o-ring for secondary shaft. I guess they should have called it an incomplete gasket set instead . I could have sworn that the pic I looked at showed the little o-ring. the one on the shaft looks ok, should I reuse it? How important is it to have a perfect seal on the main and secondary shaft? the other shaft doesnt have one
2005 KDX220 mine
2005 KDX220 mine
- krazyinski
well the one on the right side leaks on mine started after about 50 hours when she is running real rich it drips on my boot when shes just right she barely leaks at all.
So instead of worry I use it as a gauge for tunning it will leak there befor it drips out the pipe. so the answer is--- beats Me???
