went to clean the stock spark arretor and
the manual say bring bike to operating temp and remove plug tap with rubber mallet til carbon particals come out . Mine had no particals instead it looked like changing the oil on my pick up WTF whats going on
Kauai Boy 04 kdx 200
Sounds like your running a little rich there Sky!
Ditto what Indawoods stated.
Also depends somewhat on the oil you run - a number of the synthetic oils do not seem to produce the carbon particles that their dino cousins produce. I find that running a good synthetic oil may leave an spooge covered PV and some spooge coating in my pipe but the carbon build-up that I use to experience in the header area of the pipe and in the spark arrestor just does not happen.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
OUCH! That's at least part of the problem I think. That stuff is bad sticky....
But IC is right... the synth stuff doesn't create carbon like the dino stuff since it doesn't have any organic material in it.
If I was you, I'd but some better oil than the Bel-Ray because it gums up the KIPS bad.
Amsoil or Motul would be the way to go.....
I know the Amsoil Interceptor is run at 50:1 and it is what I run. It is made for clean powervalves.
I run the BR8ES as you....
Above 6K.... sure!
