Posted: 05:47 pm Feb 08 2005
Revalving is pretty much always a good plan. If for no other reason than it's (hopefully) something that is done with YOU in mind...not just one more bike with a bunch of parts destined for a spot in a showroom line somewheres.
I spent a good deal of $$ on my suspension..front and back. When I got it back I wasn't too impressed. 'Gee. Not a whole lot of bang for THOSE hundreds of $$!' I said to myself.
Then I had an opportunity to ride a kdx with oem suspension. It about scairt me to the point of soiling myself. Man! It was bad!!
Clickers should be 'in the middle' only if that's where they end up after tuning your suspension. Have you been through the suspension setting routine? Accelerating bumps, braking bumps, crabbing front-end, etc etc etc? Two clicks on my bike make a huge difference!! Easy to feel. Little things like pressure bleeds on the forks are a big deal, too! Well, imo.
It's all a matter of a whole bunch of little steps. They all add up. Some things do common-sensibly come first. Not a lot of point in spending money on a revalve if you haven't bothered to tune what you got. What are you going to do with your new revalve? Ride it like it comes out of the box? That's a waste of good money. Learn the tuning method now so you know what to do when you get the hi-$$ revalve done.
If you don't have a suspension primer bookmarked..let us know. Somebody will send you some good links. There used to be a pretty good one on MX-Tech's site.
Basically, ride over some whoops..pay attention to what the backend is doing. Kicks your arse off the seat on the way up? Too much compression. Kicks the tire off the ground at the top? Too little (too fast) rebound. Successive whoops get worse and worse (packing)? Too much (too slow) rebound.
Forks? Set 'em as soft as you can and not have it bottom more than once in a great while.
Sag? Set to 4". Resultant free sag should be 5/8-1 1/4" or so. Not enough? Shock spring is too light. Too much? Shock spring is too heavy.
Tune what you got (suspension) first. If $150 is the target price the DF3 fits. Closer to $190 for the carb with shipping and one'a those cute finger adjustable air screws! :)
