Kdx creeping forward in gear
Posted: 02:55 pm Aug 31 2006
by motofox2006
It might be my clutch plates but it wouldn't be because ive stuck 10w-40 four stroke engine oil it would it
Posted: 03:05 pm Aug 31 2006
by strider80
Your clutch basket is probably worn and the plates are hanging up.
Posted: 03:47 pm Aug 31 2006
by motofox2006
what you mean hanging up
Posted: 04:45 pm Aug 31 2006
by strider80
The clutch plate fingers have to slide on the aluminum clutch basket, over time grooves start forming and do not allow them to slide. You need to dissasemble the clutch and file the clutch basket. It will be obvious if you take it apart.
Re: Kdx creeping forward in gear
Posted: 07:48 pm Aug 31 2006
by Green Hornet
motofox2006 wrote:It might be my clutch plates but it wouldn't be because ive stuck 10w-40 four stroke engine oil it would it
NYKDXer used the 4 Stroke Crap & the same happened to him, Put another fluid in it.
Posted: 11:10 pm Aug 31 2006
by motofox2006
Thanks for the info ill try the oil first. Then if that doesnt work ill check the clutch basket.
Thanks all
Posted: 12:27 am Sep 01 2006
by strider80
A cheap easy oil for the tranny that works well is 15w-40 diesel oil like Chevron Delo 400, Shell Rotella or Amsoil diesel synthetic (what I use, more expensive). But that is only my opinion, a lot of oils work well.
Posted: 02:02 am Sep 01 2006
by motofox2006
Posted: 08:55 am Sep 01 2006
by nykdxer
Yes I also put 4 stroke oil in my bike and the plates stuck also when i tried to kick it in gear it would lunge forward. Thought my clutch was gone but i put in some 10-40 rode it for a while then changed it again and it seems to be ok now. I don't remember which 4 stroke oil it was but if i do I'll post it
Posted: 04:41 pm Sep 01 2006
by motofox2006
ok i used motul 10w-40 4 stroke oil and mines creeping forward.
Ill change the oil today
Posted: 08:25 pm Sep 01 2006
by fuzzy
See if that fixes it. Motul does make "transoil" designed specifically for 2-stroke trannies, and it's good stuff.
Posted: 12:24 am Sep 02 2006
by RBD
Adjust it !!!!!!!
Posted: 02:51 am Sep 03 2006
by motofox2006
have done and it6s not the problem ive also tryed the oil and it appears to be something to do with my clutch thanks for all the help guys
