stiffer kdx fork springs
motofox2006
Post by motofox2006 »
Hi guys can anyone tell me what stiffer fork springs out of xr400 0.38kg springs and OEM kdx 1995-2005 0.35kg springs I need.
I weigh 146Lbs (66kg)
Jeff Fredette says on his site that for my weight category i need 0.35kg/mm springs for my weight. However on Race Tech spring calculator it says i need 0.40kg springs for my weight.
Anyone got any ideas.
Any help appreciated Thanx guys
E series 91 KDX
krazyinski
Post by krazyinski »
go with the .35 for your size or .38. I am 165 and run the .40
m0rie
Post by m0rie »
I ran 0.40kg XR400 springs in my stock 89 forks. Worked well for my 175lbs weight after I got the oil weight down (7w from 10w) and ran a minimal amount of preload (3mm). I'd try 0.35kg 95+ KDX stock springs for your current weight. I've got a set if your interested in giving them a try.
motofox2006
Im interested but are the springs your on about on ebay or are you putting them on their and how much you looking for thanx
E series 91 KDX
motofox2006
just wonder if i go with the xr springs because they are 520mm long instead of the kdx 470mm long spring when the xr springs compress will i end up with coil bind has anyone here had any problems like this
E series 91 KDX
