Master cylinder screw size?
- strider80
I don't have the KDX in front of me to check, does anyone know the size of the master cylinder screws that hold on the reservoir cap? I want to flush my brake fluid again and the last time I had to dremel in a slot into the screws because the phillips stripped out, so I would like to replace them this time around.
2005 KTM 250EXC
2000 KDX200 (gone)
2000 KDX200 (gone)
- quailchaser
If I remeber correctly, kelasaki is correct...M4. I had the same problem but ended up having to drill one of them out. I went to ACE Hardware and got allen head SS screws to replace them...I took the old one with me to compare length and size.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
I know this thread is old but . . . Just a quick word of thanks for this thread - and others related to what to do with seized master cylinder screws. You guys offer great advice and without it, I would have never fallen BACK in love with riding and restoring KDX's! This information is always relevant!
- 6 Riders
Re: Master cylinder screw size?
One more add to an old thread;
When removing these screws, after a longtime wait, use an impact driver. The type that you hit with a hammer to make it turn. This will crack these nasty little screws loose w/o a problem. Don't "BTSOI" it will just need enough "hammer force" to get the driver to turn a little bit. Replace the screws as necessary w/whatever type you prefer and keep a couple in your "parts bin".
