My first tear down
liv2ride626
My first tear down
Post by liv2ride626 »
I am unable to ride for the next couple months so I figured its the perfect time to give my bike a good once over. I am planning on replacing the water pump impeller, rings and possibly the piston. Are there any other things I should keep an eye out for or replace? Any input is appreciated
Thanks
-Donovan
santod
Post by santod »
have you done the bearings yet?
kdxquebec
Post by kdxquebec »
Hi.
Power valves cleaning.
Grease or replace swing arm/linkage bearings and head set bearings.
Change fork and shock oil
Put new air in the tires :mrgreen:
liv2ride626
santod wrote:have you done the bearings yet?
Which bearings are you referring to? As quebec said I was thinking swingarm linkage, but not much else. I have a lot of time so It could keep me going.
santod
Post by santod »
swingarm, shock, linkage, wheel, and steering.
crazyaboutriding
Post by crazyaboutriding »
ya. when you put it back together, make sure the govenor for the kips is put in carefully. i've had bad luck with that :wink:
Kevin
'00 KDX 200
