countershaft (sprocket) leak need advices...
- kdxquebec
Hi. My countershaft seal lip is cut(broken) at one place so I need to repace it.I have heard some method to remove the seal but witch is the better? How YOU did it?
I am down for 2 weeks because my finger came between the chain and rear sprocket when my wheel was turning!Where is my nail? eh...... so this is the time to replace the seal.
I will order a new seal,bushing and 2 orings.
thanks a lot and good summer holydays!
- m0rie
Ouch! Just use a dental pick and pull the seal out. Don't forget to put grease on the seal when you reinstall it.
- kdxquebec
Yeah yeah yeah..same old etc...
But I forgot the answer!
From m0rie's comment, the KDX is one bike that you can replace the seal from the OUTside?
92049-1068
BuyKawi shows this as the seal for the '89..and it is placed from the outside.
92050-033
..is the 'H' PN, different part, but placed the same way...from the outside.
OK..I guess I 'remember' now?
By 'dental pick' you are referring to a mechanic's scribe sort of thing, right?
That looks like:
If so, get a good one. The cheaper choice is not the best. Usually black in color, they break/bend quite easily. Get a silver colored one.
Now THERE'S some technical info for 'ya..the COLOR matters!!
From here:
..they cost $5.
I've paid less. Don't know about the quality of the pictured one.
I see no o-rings listed on the BuyKawi site...
**edit #four..darnit##
When I look at the bigger picture, it IS black!!
OK. From my experience, the black ones are not worth it..and I've paid a whole lot less than five bucks!! More like $1. Maybe $5 is the CAN price!
Hope this helps!
92049-1068
92050-033
That looks like:
From here:
..they cost $5.
Hope this helps!
- m0rie
Yeah I meant a mechanics scribe. Except the ones in my tool kit really are dental picks!
- KDXer
I feel your pain Philippe, I put my first 2 fingers through the front sprocket on my BMX when I was younger. I had 'back pedal' brakes and had to turn the sprocket 1 revolution to get my fingers out.
Back on topic.
Can you pick the seal out with the output shaft in place ??
Back on topic.
- m0rie
Yeah the counter shaft stays in place. Check the collar while you have the seal out. If its grooved at all your going to want to replace it as well or the seal will just start leaking again.
Finger between any chain and sprocket got to hurt!!
If a dental pick doesn't work for you and there is any sort of metal outer housing on the seal drill a small hole in the outer metal housing install a metal screw about 1 turn into the seal and pull it out with pliers. Usually works better with two screws located 180 degrees apart.
Disclaimer - I don't think I've ever changed a counter shaft seal on a KDX - they may or may not have a metal seal to tap into. - Good Luck and Heal Quickly
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Hey, you are supposed to use other peoples fingers for CRYING OUT LOUD.
How about the chain grabbing your Levis Jeans, and pulling your KNEE into the Front SPROCKET Left a 4 inch hole on top of my knee, could touch the knee cap. Well 50 something stiches & 27 yrs later, still works
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- kdxquebec
- m0rie
It's out! Great!
It looks like the screw was threaded in plenty far enough to take out the bearing!
Uh-oh.....
Tell me that didn't happen.....
Hey! What happened to that finger!!??
Uh-oh.....
- kdxquebec
>|QBB<[/url]
Morie: The collar was grooved just a liitle but I bought a new one anyway.
It seems that we can not reverse this collar because on one side there is a special place for the orings.
**********Hey! What happened to that finger!!?? ************
Do you want a video of the accident???????
yes?
no? eh too late sorry for smooth heart!
No worry! everything was perfect.I threaded the screw more just for the picture purposecanyncarvr wrote:It's out! Great!
yes?
Re: 'No worry! everything was perfect.I threaded the screw more just for the picture purpose.''
'Ya know...I actually considered that a possibiity!
Curious: How tight is the collar fit to the shaft? It just slipped right off? I'd think THAT would be more of a stickage problem than the seal.
- kdxquebec
The collar slipped right off... with a long nose pliers.yes.No loose, Is it normal?
The collar turn with the sprocket,correct?
The seal was really worn (17 years old) and the outter lip was broken at one place.
I presume the point is to have the seal wear a hole/ring in the sleeve as opposed to the shaft!
I would also presume the collar would fit fairly snug, else what purpose would it serve in oil control (well, some o-rings)! AND, if it was loose, what's that going to do wear-wise, metal to metal with the collar in place and the countershaft spinning?
Why that 'snug' wouldn't turn into 'stuck like glue'...I don't know.
Whatever works!
You got the seal out, AND the collar off. Life is good!
Whatever works!
- KDXer
- KDXer
Nevermind, just realized I ordered 9205<u>5</U>-03<u>5</u> and NOT 9205<u>0</u>-03<u>3</u>. Off to the stealership AGAIN...
FTR To change a H model leaky countershaft seal the following parts should be ordered.
92050-033 = OIL SEAL (like pictured above)
92055-035 x2 = O-RINGS
92143-1433 = SLEEVE/COLLAR
- KDXer
All done and sorted. Philippe you did very well to drill the seal. My seals metal edge was tiny and even with the smallest hole my screw just pulled out. I ended up bending the seal enough to pry it out. I'd like to see a dental pick / scribe pull it out. It was in there good, REAL GOOD !!
