Rim Damage
marco220
Rim Damage
Post by marco220 »
Have this rim laying around. Figured it's a good spare. Can this dent be fixed? I don't want to try and end up with more damage. Heat?
Bear with me. I tried to post the pic but I don't know if it will work (never tried it before).
http://www.kdxrider.net/forums/modules. ... _album.php
2002 KDX 220
RB'd Carb and Head
I don't crash often... but when I do, I'm going for style points!
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
If your going to run it... run it as is. They cannot be fixed.
m0rie
Post by m0rie »
I'd just run it as is while looking for a replacement. You can loosen the spoke nipples on that side and pound the dent out with a block of wood but you might just make it worse while doing it.
1989 KDX 200
2007 TTR-50E
KDXer
Post by KDXer »
I have had a wheel repaired that was 100x worse than that. It cost me $80AU. The bike got stuck WOT and launched up a gutter minus the rider.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Every expert on the subject says do not try to fix it.
It is dangerous to run it afterwards.
Like when they say don't smoke in your Meth lab... you gotta take it seriously.
krazyinski
Post by krazyinski »
If it bothers you then your on the wrong bike, you need a scooter! just kidding, I have corrected a similar halve taco, on a duel sport and had no issues at 70 mph. I took a 4X4 on the inside base of the rim and 2x4 about 1' long covering the ding outside with a five pound hammer and started hitting like your pounding a dent out of a body panel some pressure needs to be applied to the rim towards the 4x4.the rim should be up on the 4x4 at an angle 4x4 up against a wall rim at an angle.takes a helper and don't expect perfection just get the wall back there will be a little bump left but that wont be the first.
canyncarvr
Post by canyncarvr »
You can experiment with the pounding part. I have. It ends up looking like you tried to fix it by pounding on it with a hammer.
I'd never heat it.
Mr. Wibbens
Post by Mr. Wibbens »
I've heard good things about these guys:
http://www.woodyswheelworks.com/moto_wheels.shtml
Mr. Wibbens
Yeah, personally I have a hard time seeing anything wrong with it
I'e seen some dinged up rims but that aint nuttin!
wanaride
Post by wanaride »
I've been running my front rim with a similar dent for over 2 years, no problem.
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
IdahoCharley
Post by IdahoCharley »
From the picture I would probably just run it the way it is. Does not look like the ding is enough to upset the tire bead.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
