Water Pump Replacemnt part 2
cfspawn
Post by cfspawn »
Hi all
I have now completly reassmbled my water pump and side cover with new bearing, mechanical seal, and oil seal as well as the shaft itself. once i put it back together i noticed the the impeller shaft is alot harder to turn. this seems normal to me as its got new seals and bearings. and its dry with no oil on them yet. just wanted to check if anyone else had this problem :twisted:
The test is fill it up, start it... then remove the cap and see how it's flowing.
cfspawn
Post by cfspawn »
Im sure its fine i think it just has that "newness" to it
Colorado Mike
Re: Water Pump Replacemnt part 2
Post by Colorado Mike »
cfspawn wrote:... once i put it back together i noticed the the impeller shaft is alot harder to turn....
The thing turns when it's back together? I would have thought the drive gears would prevent that. Well, unless you're able to turn the motor over by twisting the impeller, which I wouldn't think was spec'd in it's design.
cfspawn
Post by cfspawn »
naa bud your right the impeller doesnt turn when untill you turn over the bike.
i was talking about when you have the side cover off
